[Gdal-dev] DODS format build error
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 28 14:54:46 EDT 2006
William Kyngesburye wrote:
> I finally got a version of libdap to build on OS X, so I tried adding it
> to GDAL. GDAL 1.3.1 + DAP 3.6.2. (I looked at the GDAL snapshot for
> today, but no changes in dods code, so I didn't bother to try building it)
> It's the exact same error as the 2nd part of bug 891, which is supposed
> to be fixed (and I do see the fix there in ogr_dods.h):
> dodsdataset2.cpp: In constructor ‘DODSDataset::DODSDataset()’:
> dodsdataset2.cpp:307: error: no matching function for call to ‘DDS::DDS()’
> /usr/local/gislibs/include/libdap/DDS.h:254: note: candidates are:
> DDS::DDS(const DDS&)
> Maybe there's a new compatibility option for the 3.5 -> 3.6 update?
> Should I add a new bug for this? Or should the old bug be reopened?
William,
If you create a new bug I'll see what I can do. I've got to upgrade
to the latest DAP libraries and fix things up anyways. Oh, will I ever
get this release out the door? I do appreciate the good feedback I'm
getting though!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
