[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Charlie Savage
cfis at savagexi.com
Sat Aug 5 15:55:18 EDT 2006
In gdal.i add
%include "typemaps.i"
*before* the code you pasted below (so it is loaded before gdal_typemaps.i)
Charlie
Daniele Romagnoli wrote:
> gdal.i include band.i (band.i contains "our" getBlockSize method)
> furthermore, gdal.i contains this code:
> #if defined(SWIGPYTHON)
> %include "gdal_python.i"
> #elif defined(SWIGRUBY)
> %include "gdal_ruby.i"
> #elif defined(SWIGPHP4)
> %include "gdal_php.i"
> #elif defined(SWIGCSHARP)
> %include "gdal_csharp.i"
> #elif defined(SWIGPERL)
> %include "gdal_perl.i"
> #elif defined(SWIGJAVA)
> %include "gdal_java.i"
> #else
> %include "gdal_typemaps.i"
> #endif
> and gdal_java.i contains this code:
> %include typemaps_java.i
> (while other languages include the proper typemaps_language.i)
> This "include" mechanism should work?
> Or I explicitly need to include something else somewhere?
> Thanks again.
> Cheers
> Daniele
> On 8/5/06, *Charlie Savage* < cfis at savagexi.com
> <mailto:cfis at savagexi.com>> wrote:
> Sorry, typemaps.i is what I meant. I don't see it included anywhere
> except in the csharp.i file.
> Try putting it in gdal.i instead - that will cause all languages to use
> it. If that works, it probably should be removed from csharp.i. And
> added to ogr.i (not sure if there is one central .i file it go into,
> doesn't look like it).
> Charlie
> > I'm sorry Charlie...
> > Please, throw away my previous email (which contains a typo)...
> > This one is corrected:
> > There is no sign of templates.i in my code (neither in the gdal
> and swig
> > subfolders).
> > Furthermore, there is no trace of templates.i in the suggested
> http link :(
> > Maybe are you talking about typemaps.i?
> > I'm sure that typemaps.i is included.
> > Best Regards,
> > Daniele
> > ---------- Forwarded message ----------
> > From: *Daniele Romagnoli* < dany.geotools at gmail.com
> <mailto:dany.geotools at gmail.com>
> > <mailto:dany.geotools at gmail.com <mailto:dany.geotools at gmail.com>>>
> > Date: Aug 5, 2006 8:03 PM
> > Subject: Re: gdal swig interface Band.i Updated
> > To: Charlie Savage < cfis at savagexi.com <mailto:cfis at savagexi.com>
> <mailto:cfis at savagexi.com <mailto:cfis at savagexi.com>>>
> > On 8/5/06, *Charlie Savage* <cfis at savagexi.com
> > <mailto:cfis at savagexi.com <mailto:cfis at savagexi.com>>> wrote:
> > Check to see if templates.i is included.
> > See:
> > http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5
> > <http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5>
> and swig
> > subfolders).
> > Furthermore, there is no trace of typemaps.i in the suggested
> http link :(
> > Best Regards,
> > Daniele
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060805/a2990dc6/smime.bin
