[Gdal-dev] Re: Fwd: gdal swig interface Band.i Updated
Daniele Romagnoli
dany.geotools at gmail.com
Sat Aug 5 15:31:13 EDT 2006
gdal.i include band.i (band.i contains "our" getBlockSize method)
furthermore, gdal.i contains this code:
#if defined(SWIGPYTHON)
%include "gdal_python.i"
#elif defined(SWIGRUBY)
%include "gdal_ruby.i"
#elif defined(SWIGPHP4)
%include "gdal_php.i"
#elif defined(SWIGCSHARP)
%include "gdal_csharp.i"
#elif defined(SWIGPERL)
%include "gdal_perl.i"
#elif defined(SWIGJAVA)
%include "gdal_java.i"
#else
%include "gdal_typemaps.i"
#endif
and gdal_java.i contains this code:
%include typemaps_java.i
(while other languages include the proper typemaps_language.i)
This "include" mechanism should work?
Or I explicitly need to include something else somewhere?
Thanks again.
Cheers
Daniele
On 8/5/06, Charlie Savage <cfis at savagexi.com> wrote:
> Sorry, typemaps.i is what I meant. I don't see it included anywhere
> except in the csharp.i file.
> Try putting it in gdal.i instead - that will cause all languages to use
> it. If that works, it probably should be removed from csharp.i. And
> added to ogr.i (not sure if there is one central .i file it go into,
> doesn't look like it).
> Charlie
> Daniele Romagnoli wrote:
> > I'm sorry Charlie...
> > Please, throw away my previous email (which contains a typo)...
> > This one is corrected:
> > There is no sign of templates.i in my code (neither in the gdal and swig
> > subfolders).
> > Furthermore, there is no trace of templates.i in the suggested http link
> > Maybe are you talking about typemaps.i?
> > I'm sure that typemaps.i is included.
> > Best Regards,
> > Daniele
> > ---------- Forwarded message ----------
> > From: *Daniele Romagnoli* <dany.geotools at gmail.com
> > <mailto:dany.geotools at gmail.com>>
> > Date: Aug 5, 2006 8:03 PM
> > Subject: Re: gdal swig interface Band.i Updated
> > To: Charlie Savage <cfis at savagexi.com <mailto:cfis at savagexi.com>>
> > On 8/5/06, *Charlie Savage* <cfis at savagexi.com
> > <mailto:cfis at savagexi.com>> wrote:
> > Check to see if templates.i is included.
> > See:
> > http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5
> > <http://www.swig.org/Doc1.3/Arguments.html#Arguments_nn5>
> > subfolders).
> > Furthermore, there is no trace of typemaps.i in the suggested http link
> > Best Regards,
> > Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060805/2cd7b850/attachment.html
