[Gdal-dev] gdal-1.3.2 build problem
Murat Şenel muratasenel at gmail.com
Mon Aug 14 07:40:52 EDT 2006
Hello to everybody
I am trying to package gdal for newly released linux distro PARDUS.
Its package-manager is different from others. We don't use deb or rpm etc.
Pardus's package-manager is called PiSi (you can find detailed info on
http://www.pardus.org.tr/eng/index.html)
Anyway, my problem occurs when I try to package gdal for Pardus and as far
as
I understand, the problem is based on gdal source codes.
You can find error message below (just some part of it). If you can help me
with this, I would be glad.
Thanks in advance
Murat \
from Turkey
>> gdal-config
echo 'CONFIG_PREFIX="/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2"' >>
gdal-config
echo 'CONFIG_CFLAGS="-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/port
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/gcore
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/alg
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/ogr
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/ogr/ogrsf_frmts"'
>> gdal-config
echo 'CONFIG_VERSION="'`cat ../VERSION`'"' >> gdal-config
echo 'CONFIG_OGR_ENABLED=no' >> gdal-config
echo 'CONFIG_FORMATS="gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm
sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk
airsar rs2 ilwis rmf rik leveller sgi idrisi bsb jpeg2000 hdf5 gif jpeg png
netcdf pcraster "' >> gdal-config
cat gdal-config.in >> gdal-config
chmod a+x gdal-config
/bin/sh /var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/libtool --mode=compile
i686-pc-linux-gnu-gcc -Wall  -mtune=i686 -O2 -pipe -fomit-frame-pointer
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/frmts
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/port  -c -o gdalinfo.o
gdalinfo.c
mkdir .libs
-I/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/port -c gdalinfo.c  -fPIC -DPIC
-o .libs/gdalinfo.o
/bin/sh /var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/libtool --mode=link
i686-pc-linux-gnu-g++  gdalinfo.o  \
        /var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/libgdal.la -o gdalinfo
gdalinfo.o -o .libs/gdalinfo
/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/.libs/libgdal.so -L/usr/lib
-L/usr/i686-pc-linux-gnu/lib -lxerces-c -lssl -lcrypto -lSM -lICE -lX11
-lnetcdf -lpq -lz -lrt -ldl -lpthread i686-pc-linux-gnu-g++: gdalinfo.o: No
such file or directory
make[1]: *** [gdalinfo] Hata 1
make[1]: Leaving directory `/var/tmp/pisi/gdal-1.3.2-1/work/gdal-1.3.2/apps'
make: *** [apps-target] Hata 2
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060814/de627fc7/attachment.html
