[Gdal-dev] building gdal for OpenZaurus
Mateusz Loskot
mateusz at loskot.net
Thu Aug 24 14:24:24 EDT 2006
Frank Warmerdam wrote:
> Yan Seiner wrote:
>> I am trying to cross-compile gdal for OpenZaurus. I am using the
>> development toolchain (3.5.4.2-rc2). The build fails with:
>> | arm-linux-g++ -march=armv5te -mtune=xscale -Wall
>> -I/home/local/zaurus/tmp/staging/arm-linux/include
>> -fexpensive-optimizations -fomit-frame-pointer -frename-registers
>> -O2 -fpermissive -DOGR_ENABLED
>> -I/home/local/zaurus/tmp/work/armv5te-linux/gdal-1.3.2-r1/gdal-1.3.2/port
>> -c cpl_strtod.cpp -fPIC -DPIC -o .libs/cpl_strtod.o |
>> cpl_strtod.cpp:239: error: declaration of `double nan(const char*)'
>> throws different exceptions |
>> /home/local/zaurus/tmp/staging/arm-linux/include/bits/mathcalls.h:225:
>> error: than previous declaration `double nan(const char*) throw
>> ()' | cpl_strtod.cpp:249: error: declaration of `float nanf(const
>> char*)' throws different exceptions |
>> error: than previous declaration `float nanf(const char*) throw
>> Can anyone shed some light on this? I am pretty much out of my
>> depth on these types of errors....
> Yan,
> The problem appears to be that cpl_strtod.cpp is providing a
> declaration for nan() that conflicts with the system one. The code
> tries to avoid this by only declaring it if the HAVE_DECL_NAN is
> unset or zero in cpl_config.h (as set by configure), but it seems
> that configure on your platform has not correctly set this item.
Frank,
My suggestion about replacing <math.h> to <cmath> fix this ambiguity,
because the latter puts everything to std:: namespace.
Though, nan is not a standard math function for C++.
Another option is there are still some bugs in gcc/libstdc++,
especially in older versions. I remember there were problems like mixing
C and C++ declaration in global space instead of std.
Yan, I'd suggest you to ask on gcc/libstdc++ mailing list too.
Here is one of my report about similar problem:
http://gcc.gnu.org/ml/libstdc++/2006-02/msg00086.html
and Joe Buck explains:
It appears that the problem is in the headers; despite the ISO
requirement, doing
#include <cstring>
on a GNU/Linux RHEL 3 system provides the C-style declaration, for
versions 3.2.3, 4.0, and 4.1-pre.
So, there still may be some similar issues.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
