[Gdal-dev] GDAL and Solaris 10/sparc
Fri Aug 25 15:36:57 EDT 2006
Shaun Kolomeitz wrote:
> Thanks Frank,
> I had a quick look at getting the IRC client to go, but our work proxy can
> be a bit difficult to get around. I will have a look at getting access via
> SSH, again this is usually not permitted because of security concerns.
> Perhaps if I could give them a specific client address, and then decide on
> a time window to allow you "through" our firewall we could have more
> success. I suspect that we have everything needed to do a successful build,
> but I am not entirely sure of what order things should be in. The 32 vs 64
> bit build is puzzling me as to which PATH and LD_LIBRARY settings are
> needed plus which system wide settings should apply. I've had success in
> the past in building ECW as a separate (standalone) entity, but not in
> getting it to link-in with GDAL. I've also managed to get an older version
> of GDAL (v1.2) working. Bugger me if I can remember how I did it now ! I'll
> contact our network people and see if I can get access via SSH granted.
Shaun,
I understand about the security issues.  This is a common issue.
I don't know the particulars of how to deal with Solaris 32/64 bit problems
and so on.  I'd just be puttering around trying to figure it out.  Though
this is something I'm pretty good at.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
