[Gdal-dev] Support for LIDAR data, LAS format?
Carl Anderson
carl.anderson at vadose.org
Fri Dec 1 01:35:10 EST 2006
Cody,
If you compile the SWIG/Python bindings into GDAL
you can use
http://www.perrygeo.net/wordpress/?p=38
To pre-process your LAS format LIDAR into a shapefile, and run on from
there.
A clever person might be able to extend the script to other GDAL
supported formats.
there is a 0.02 version of the LAS -> Shapefile script somewhere..
C.
Cody Benkelman wrote:
> Apologies for cross-posting - I posted this previously on the GeoTIFF
> list...
> Has anyone added support for LIDAR data in LAS format?
> Thanks
> Cody Benkelman
>> -----Original Message-----
>> From: Cody Benkelman [mailto:benkelman at yahoo.com]
>> Sent: Monday, November 27, 2006 10:55 AM
>> To: geotiff at lists.maptools.org
>> Subject: Support for LIDAR data, LAS format?
>> I'm seeking an update with regard to LIDAR data, in LAS format. I
>> found the exchange copied at bottom in the archive:
>> http://lists.maptools.org/pipermail/gdal-dev/2004-June/003599.html
>> ...but I don't see LAS or LIDAR in the current GDAL format list. May
>> I assume support for LAS format has not yet been added to GDAL?
>> Thanks
>> Cody A. Benkelman
>> ASPRS Certified Mapping Scientist - Remote Sensing (#RS-144)
>> Whitefish, Montana 59937 cell (406) 270-1176
>> [Gdal-dev] Re: LIDAR .las file format
>> John Nipper jnipper at bhinc.com
>> Thu Jun 24 18:44:48 EDT 2004
>> Previous message: [Gdal-dev] LIDAR .las file format Next message:
>> [Gdal-dev] reprojecting Messages sorted by: [ date ] [ thread ] [
>> subject ] [ author ]
>> Chapman, Martin <MChapman <at> sanz.com> writes:
>>> All,
>>> Has anyone written a
>>> driver for the LIDAR (.las) file format for GDAL?
>>> Martin Chapman
>>> Cell 303-885-1936
>>> Office
>>> 303-660-3933 x226
>>> mchapman <at> sanz.com
>>> http://www.sanz.com
>>> Gdal-dev mailing list
>>> Gdal-dev <at> remotesensing.org
>>> http://xserve.flids.com/mailman/listinfo/gdal-dev
>> I have written utilities that read/write las format. I have not seen
>> anything that is open source, or for GDAL yet. I would be happy to
>> help out with such a driver, if I can get permission to do so ... At
>> a minimum, I can answer questions about the format if anyone needs.
>> Thanks,
>> John Nipper
>> 505 798-7907 direct office line
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
