[Gdal-dev] Error accessing Pgeo through ODBC
Mateusz Loskot
mateusz at loskot.net
Fri Dec 1 03:27:31 EST 2006
Craig Feuerherdt wrote:
> When I attempt to use ogrinfo I get the following errors:
> ogrinfo PGeo:b_pgeo
> ERROR 1: /usr/grass-6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> ERROR 1: /usr/grass- 6.1.0/lib/libgrass_vask.so: undefined symbol: stdscr
> Segmentation fault
> I can not work out why the error involves GRASS?
I don't know too.
Please, provide more details:
1. Have you configured MDB driver for ODBC, in odbcinst.ini file?
2. What ./configure options did you used to compile GDAL?
3. Do you use MDB Tools as driver for MDB format? If you do, what
version of MDB Tools do you use?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
