[Gdal-dev] (no subject)
Howard Butler
hobu at iastate.edu
Sun Dec 3 20:18:10 EST 2006
C# and .NET require MSVC 2003. It appears as though you are using
MSVC6.
Howard
On Dec 3, 2006, at 7:02 PM, Alan wrote:
> Following the advice in http://www.nabble.com/forum/ViewPost.jtp?
> post=7196645&framed=y
> I completed “ nmake -f makefile.vc interface” successfully,
> but “nmake -f makefile.vc”
> gives the following error:
> C:\CVSCheckout\GDAL\SWIGC#\swig\csharp>nmake -f makefile.vc
> Microsoft (R) Program Maintenance Utility Version 6.00.9782.0
> Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
> sn -k gdal.snk
> 'sn' is not recognized as an internal or external command,
> operable program or batch file.
> NMAKE : fatal error U1077: 'sn' : return code '0x1'
> Stop.
> Could someone please suggest what I’m missing?
> Thanks
> AlanK
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
