[Gdal-dev] ogr2ogr Default Output SRS
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 7 17:22:59 EST 2006
Bill Thoen wrote:
> Am I missing something here? When I use ogr2ogr to export a shapefile I
> don't have to specify an output SRS; it seems happy to use the one
> specified in the geometry_columns table. But when I try to export a
> MapInfo tab file I MUST specify either -t_srs or -a_srs or I get a error
> saying it couldn't open the file with any of its drivers.
Bill,
This should not be the case. Can you submit a bug, including details
on the software version you are running (CVS head I guess) and attaching
a dataset that demonstrates the problem?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
