[Gdal-dev] gdaladdo -r average tiled.img 2 4 8 16 32 64 128 does not give 100 -done message at the end
John Mitchell mitchelljj98 at gmail.com
Mon Dec 18 07:41:57 EST 2006
I converted a GeoTiff to a Erdas Imagine format by running the below statement:
gdal_translate -of HFA original.tif tiled.img
I then build internal overviews to the image file by running:
My concern is that it counts down from 0... to 90... 3 times but never
reaches 100 - done.  When I run the same command against the GeoTiff it
counts once from 0... to 90...100 - done.  I have successfully opened both
files in OpenEV_FW and they look identical.
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061218/c0b57056/attachment.html
