[Gdal-dev] GDAL_warp output image sizes vary.... Why?
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 20 13:10:23 EST 2006
Sampson, David wrote:
> List,
> Here are some of the results of tiffinfo.
> Sorry about incorrect info. I meant the image starts at 16 bit and ends
> off as 8 bit.
> Here are the appropriate outputs
Dave,
Despite my hopes, there is nothing like compression to explain this.
If you can supply me with an input file, a gdal_translate or gdalwarp
commandline and the output file you get that is noticably larger I can
look into this in more detail. It is not at all obvious why this
should be happening.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
