[Gdal-dev] Problem with MapInfo file and NTF system
Jean-Claude Repetto
jean-claude.repetto at worldonline.fr
Thu Dec 21 08:27:49 EST 2006
Hello,
I have downloaded a vectorial map of France in MapInfo format (freely
available from the IGN website at
<http://www.ign.fr/telechargement/MPro/produit/GEOFLA_Dep/GEOFLA-dep-L2-MM.ZIP>
I am trying to convert it to WGS84 with ogr2ogr, but the result is
wrong, the longitudes have an offset of 2.33° (corresponding to the
Paris prime meridian).
The original file contains this definition of CS and projection :
CoordSys Earth Projection 3, 1002, "m", 0, 46.8, 45.898918964419,
47.696014502038, 600000, 2200000 Bounds (-113967455.417, -
106367759.649) (115167455.417, 122767151.185)
Projection type 3 = Lambert Conformal Conic
Datum 1002 = datum name: Nouvelle Triangulation Francaise (NTF) Paris
Prime Meridian
Area: France
Ellipsoid: Modified Clarke 1880
But ogrinfo gives that information :
Layer SRS WKT:
PROJCS["unnamed",
GEOGCS["unnamed",
DATUM["NTF_Paris_Meridian",
SPHEROID["Clarke 1880 (modified for
IGN)",6378249.2,293.4660213],
TOWGS84[-168,-60,320,-0,-0,-0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",45.898918964419],
PARAMETER["standard_parallel_2",47.696014502038],
PARAMETER["latitude_of_origin",46.8],
PARAMETER["central_meridian",0],
PARAMETER["false_easting",600000],
PARAMETER["false_northing",2200000],
UNIT["Meter",1]]
Shouldn't the central_meridian be equal to 2.33° ?
(I am using GDAL 1.3.2).
Regards,
Jean-Claude
