[Gdal-dev] Problem with MapInfo file and NTF system
Jean-Claude Repetto jean-claude.repetto at worldonline.fr
Thu Dec 21 12:12:18 EST 2006
Frank Warmerdam a écrit :
> Jean-Claude Repetto wrote:
>> Hello,
>> I have downloaded a vectorial map of France in MapInfo format (freely
>> available from the IGN website at
>> <http://www.ign.fr/telechargement/MPro/produit/GEOFLA_Dep/GEOFLA-dep-L2-MM.ZIP>
>> I am trying to convert it to WGS84 with ogr2ogr, but the result is
>> wrong, the longitudes have an offset of 2.33° (corresponding to the
>> Paris prime meridian).
> Jean-Claude,
> There have been some significant fixes related to prime meridians in
> GDAL/OGR
> and PROJ this year, so I'd appreciate your verifying the problem with a
> 1.4.0
> beta build of GDAL and PROJ 1.5.0.  One easy way is to use FWTools:
>   http://fwtools.maptools.org/
> If the problem is still present then please file a bug on the issue.  I
> believe I did not take into announce prime meridians when writing the
> spatial reference code for the mapinfo driver, so that is likely the
> problem.
> Best regards,
The problem is still present with GDAL 1.4.0beta2 and PROJ 1.5.0.
I have filed a bug
(<http://bugzilla.remotesensing.org/show_bug.cgi?id=1416>)
Best regards,
