[Gdal-dev] struggling with ogrinfo and vmap data
Bruce Bushby
bruce.bushby at rmsaudio.com
Thu Dec 28 09:41:01 EST 2006
Hi
I've been struggling to query vmap data using ogrinfo and hoping somebody
could point me in the right direction?
I have "cleaned" the vmap data so that ALL capitals have been converted to
lower case.
This is my command and output:
[root at gis ~]# ogrinfo --debug on -ro gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer
OGR: OGROpen(gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer) failed.
FAILURE:
Unable to open datasource `gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the following drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> KML
-> OGDI
[root at gis ~]#
My setup/compilation is as follows (Fedora Core 6 [X86_64]):
expat-2.0.0
./configure;make install;ldconfig
zlib-1.2.3
./configure --shared --prefix=/usr/local; make install; ldconfig
proj-4.5.0
./configure; make install; ldconfig
ogdi-3.1.5
export TOPDIR=`pwd`
./configure --with-zlib --with-expat --with-proj; make install; ldconfig
gdal-1.4.0beta2
./configure --with-ogdi=/usr/local; make install; ldconfig
I have also pasted the output of a strace in case it helps. Looking at the strace, ogrinfo
does attempt to read the data:
"read(3, "\267\0\0\0L;Coverage Attribute Table;-"..., 4096) = 643"
Going through the strace, it looks for "gdalplugins"...which I don't have?
Also, it tries to open a "cax" file which does not exist in my map data?
Any help or pointers would be much appreciated!
Regards
Bruce
STRACE OUTPUT:
[root at gis ~]# strace ogrinfo -ro gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer
execve("/usr/local/bin/ogrinfo", ["ogrinfo", "-ro", "gltp:/vrf/tmp/vmap0/v0noa/vmaplv"...], [/* 28 vars */]) = 0
brk(0) = 0x603000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5481fe8000
uname({sys="Linux", node="gis.celtec.co.uk", ...}) = 0
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=172753, ...}) = 0
mmap(NULL, 172753, PROT_READ, MAP_PRIVATE, 3, 0) = 0x2b5481fe9000
close(3) = 0
open("/usr/local/lib/libgdal.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\6\16"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=4607087, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5482014000
mmap(NULL, 6305160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54821e9000
mprotect(0x2b5482573000, 2093056, PROT_NONE) = 0
mmap(0x2b5482772000, 413696, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x389000) = 0x2b5482772000
mmap(0x2b54827d7000, 87432, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54827d7000
close(3) = 0
open("/usr/local/lib/libogdi31.so", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260m\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=150802, ...}) = 0
mmap(NULL, 2227928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54827ed000
mprotect(0x2b548280c000, 2097152, PROT_NONE) = 0
mmap(0x2b5482a0c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5482a0c000
close(3) = 0
open("/usr/lib64/libgif.so.4", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\35\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=34552, ...}) = 0
mmap(NULL, 2129832, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5482a0d000
mprotect(0x2b5482a15000, 2093056, PROT_NONE) = 0
mmap(0x2b5482c14000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b5482c14000
close(3) = 0
open("/usr/lib64/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P5\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=139296, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5482c15000
mmap(NULL, 2234544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5482c16000
mprotect(0x2b5482c37000, 2097152, PROT_NONE) = 0
mmap(0x2b5482e37000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x2b5482e37000
close(3) = 0
open("/usr/lib64/libtiff.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20v\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=365280, ...}) = 0
mmap(NULL, 2461640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5482e38000
mprotect(0x2b5482e8f000, 2093056, PROT_NONE) = 0
mmap(0x2b548308e000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x56000) = 0x2b548308e000
close(3) = 0
open("/usr/lib64/libpng12.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0H\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=147144, ...}) = 0
mmap(NULL, 2242312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5483091000
mprotect(0x2b54830b4000, 2097152, PROT_NONE) = 0
mmap(0x2b54832b4000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b54832b4000
close(3) = 0
open("/lib64/librt.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300#\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=50320, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b54832b5000
mmap(NULL, 2132968, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54832b6000
mprotect(0x2b54832be000, 2093056, PROT_NONE) = 0
mmap(0x2b54834bd000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b54834bd000
close(3) = 0
open("/usr/lib64/libcurl.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\257"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=249736, ...}) = 0
mmap(NULL, 2345608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54834bf000
mprotect(0x2b54834fa000, 2097152, PROT_NONE) = 0
mmap(0x2b54836fa000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x2b54836fa000
close(3) = 0
open("/usr/lib64/libgssapi_krb5.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000`\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=171336, ...}) = 0
mmap(NULL, 2266896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54836fc000
mprotect(0x2b5483725000, 2093056, PROT_NONE) = 0
mmap(0x2b5483924000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x2b5483924000
close(3) = 0
open("/usr/lib64/libkrb5.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 s\1\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=553008, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5483926000
mmap(NULL, 2648352, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5483927000
mprotect(0x2b54839aa000, 2097152, PROT_NONE) = 0
mmap(0x2b5483baa000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x83000) = 0x2b5483baa000
close(3) = 0
open("/usr/lib64/libk5crypto.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000U\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=150568, ...}) = 0
mmap(NULL, 2246920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5483bae000
mprotect(0x2b5483bd1000, 2097152, PROT_NONE) = 0
mmap(0x2b5483dd1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b5483dd1000
close(3) = 0
open("/lib64/libcom_err.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\f\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=8000, ...}) = 0
mmap(NULL, 2103320, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5483dd3000
mprotect(0x2b5483dd5000, 2093056, PROT_NONE) = 0
mmap(0x2b5483fd4000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b5483fd4000
close(3) = 0
open("/lib64/libresolv.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3603\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=89792, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5483fd5000
mmap(NULL, 2181864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5483fd6000
mprotect(0x2b5483fe7000, 2097152, PROT_NONE) = 0
mmap(0x2b54841e7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x2b54841e7000
mmap(0x2b54841e9000, 6888, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54841e9000
close(3) = 0
open("/lib64/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\17\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=20520, ...}) = 0
mmap(NULL, 2109728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54841eb000
mprotect(0x2b54841ee000, 2093056, PROT_NONE) = 0
mmap(0x2b54843ed000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x2b54843ed000
close(3) = 0
open("/usr/lib64/libidn.so.11", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220/\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=202592, ...}) = 0
mmap(NULL, 2297840, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54843ef000
mprotect(0x2b5484420000, 2093056, PROT_NONE) = 0
mmap(0x2b548461f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x2b548461f000
close(3) = 0
open("/lib64/libssl.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\"\1"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=299976, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5484620000
mmap(NULL, 2395424, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5484621000
mprotect(0x2b5484664000, 2097152, PROT_NONE) = 0
mmap(0x2b5484864000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x43000) = 0x2b5484864000
close(3) = 0
open("/lib64/libcrypto.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0d\5\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1324224, ...}) = 0
mmap(NULL, 3434488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b548486a000
mprotect(0x2b548498f000, 2093056, PROT_NONE) = 0
mmap(0x2b5484b8e000, 126976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x124000) = 0x2b5484b8e000
mmap(0x2b5484bad000, 14328, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b5484bad000
close(3) = 0
open("/usr/local/lib/libz.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\36\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=118627, ...}) = 0
mmap(NULL, 2205160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5484bb1000
mprotect(0x2b5484bcc000, 2093056, PROT_NONE) = 0
mmap(0x2b5484dcb000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x2b5484dcb000
close(3) = 0
open("/usr/lib64/libstdc++.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \364\4\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=981840, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5484dcc000
mmap(NULL, 3153696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5484dcd000
mprotect(0x2b5484eb4000, 2097152, PROT_NONE) = 0
mmap(0x2b54850b4000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe7000) = 0x2b54850b4000
mmap(0x2b54850bd000, 73504, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54850bd000
close(3) = 0
open("/lib64/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260?\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=611880, ...}) = 0
mmap(NULL, 2629848, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54850cf000
mprotect(0x2b5485151000, 2093056, PROT_NONE) = 0
mmap(0x2b5485350000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x81000) = 0x2b5485350000
close(3) = 0
open("/lib64/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\37\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=54672, ...}) = 0
mmap(NULL, 2150376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5485352000
mprotect(0x2b548535f000, 2093056, PROT_NONE) = 0
mmap(0x2b548555e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x2b548555e000
close(3) = 0
open("/lib64/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\333\1\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1672888, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b548555f000
mmap(NULL, 3461304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5485560000
mprotect(0x2b54856a4000, 2097152, PROT_NONE) = 0
mmap(0x2b54858a4000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x144000) = 0x2b54858a4000
mmap(0x2b54858a9000, 16568, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54858a9000
close(3) = 0
open("/lib64/libexpat.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340;\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=141008, ...}) = 0
mmap(NULL, 2236256, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b54858ae000
mprotect(0x2b54858ce000, 2093056, PROT_NONE) = 0
mmap(0x2b5485acd000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5485acd000
close(3) = 0
open("/usr/local/lib/libproj.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\254\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=423295, ...}) = 0
mmap(NULL, 2473312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5485ad0000
mprotect(0x2b5485b29000, 2097152, PROT_NONE) = 0
mmap(0x2b5485d29000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x59000) = 0x2b5485d29000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5485d2c000
open("/usr/lib64/libX11.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\377"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1093112, ...}) = 0
mmap(NULL, 3190376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5485d2d000
mprotect(0x2b5485e31000, 2097152, PROT_NONE) = 0
mmap(0x2b5486031000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x104000) = 0x2b5486031000
close(3) = 0
open("/lib64/libpthread.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`X\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=138080, ...}) = 0
mmap(NULL, 2200432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5486038000
mprotect(0x2b548604d000, 2093056, PROT_NONE) = 0
mmap(0x2b548624c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x2b548624c000
mmap(0x2b548624e000, 13168, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b548624e000
close(3) = 0
open("/usr/lib64/libkrb5support.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\34\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=30088, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5486252000
mmap(NULL, 2125392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5486253000
mprotect(0x2b548625a000, 2093056, PROT_NONE) = 0
mmap(0x2b5486459000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x2b5486459000
close(3) = 0
open("/usr/lib64/libXau.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\16\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=10064, ...}) = 0
mmap(NULL, 2105328, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b548645a000
mprotect(0x2b548645c000, 2093056, PROT_NONE) = 0
mmap(0x2b548665b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b548665b000
close(3) = 0
open("/usr/lib64/libXdmcp.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\23\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=20136, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b548665c000
mmap(NULL, 2115384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b548665d000
mprotect(0x2b5486662000, 2093056, PROT_NONE) = 0
mmap(0x2b5486861000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x2b5486861000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5486862000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5486863000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5486864000
arch_prctl(ARCH_SET_FS, 0x2b5486863ae0) = 0
mprotect(0x2b548624c000, 4096, PROT_READ) = 0
mprotect(0x2b54858a4000, 16384, PROT_READ) = 0
mprotect(0x2b5485350000, 4096, PROT_READ) = 0
mprotect(0x2b54850b4000, 24576, PROT_READ) = 0
mprotect(0x2b54843ed000, 4096, PROT_READ) = 0
mprotect(0x2b54841e7000, 4096, PROT_READ) = 0
mprotect(0x2b54834bd000, 4096, PROT_READ) = 0
mprotect(0x2b54821e7000, 4096, PROT_READ) = 0
munmap(0x2b5481fe9000, 172753) = 0
set_tid_address(0x2b5486863b70) = 8229
syscall_273(0x2b5486863b80, 0x18, 0x7fff28ad9418, 0x2b5481fce4a0, 0x2b5486863ae0, 0x2b5481fe82b8, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3) = 0
rt_sigaction(SIGRTMIN, {0x2b548603d4a0, [], SA_RESTORER|SA_SIGINFO, 0x2b5486045de0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x2b548603d3f0, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x2b5486045de0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
futex(0x2b54850bec88, FUTEX_WAKE, 2147483647) = 0
brk(0) = 0x603000
brk(0x624000) = 0x624000
open("/usr/local/lib/gdalplugins", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = -1 ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9130) = -1 ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90d0) = -1 ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90b0) = -1 ENOENT (No such file or directory)
open("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9100) = -1 ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9120) = -1 ENOENT (No such file or directory)
futex(0x2b54843ee10c, FUTEX_WAKE, 2147483647) = 0
close(3) = 0
open("/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or directory)
open("/lib64/tls/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/lib64/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/lib64/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or directory)
open("/lib64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib64/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or directory)
open("/usr/lib64/vrf", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/lib64", {st_mode=S_IFDIR|0755, st_size=98304, ...}) = 0
close(3) = 0
open("/usr/local/lib/libvrf.so", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`S\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=195623, ...}) = 0
mmap(NULL, 2276864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b5486865000
mprotect(0x2b5486889000, 2097152, PROT_NONE) = 0
mmap(0x2b5486a89000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x2b5486a89000
close(3) = 0
mmap(NULL, 253952, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5482015000
access("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", F_OK) = 0
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 3
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
close(4) = 0
fstat(3, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b5482053000
mmap(NULL, 8017316959253172224, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = -1 ENOMEM (Cannot allocate memory)
brk(0x6f433b4c0063d000) = 0x624000
mmap(NULL, 8017316959253307392, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = -1 ENOMEM (Cannot allocate memory)
mmap(NULL, 134217728, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0x2b5486a91000
munmap(0x2b5486a91000, 22474752) = 0
munmap(0x2b548c000000, 44634112) = 0
mprotect(0x2b5488000000, 135168, PROT_READ|PROT_WRITE) = 0
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.;1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.;1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.;1", O_RDONLY) = -1 ENOENT (No such file or directory)
close(3) = 0
munmap(0x2b5482053000, 4096) = 0
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 2), ...}) = 0
write(1, "FAILURE:\n", 9FAILURE:
) = 9
write(1, "Unable to open datasource `gltp:"..., 97Unable to open datasource `gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the following drivers.
) = 97
write(1, " -> ESRI Shapefile\n", 20 -> ESRI Shapefile
) = 20
write(1, " -> MapInfo File\n", 18 -> MapInfo File
) = 18
write(1, " -> UK .NTF\n", 13 -> UK .NTF
) = 13
write(1, " -> SDTS\n", 10 -> SDTS
) = 10
write(1, " -> TIGER\n", 11 -> TIGER
) = 11
write(1, " -> S57\n", 9 -> S57
) = 9
write(1, " -> DGN\n", 9 -> DGN
) = 9
write(1, " -> VRT\n", 9 -> VRT
) = 9
write(1, " -> AVCBin\n", 12 -> AVCBin
) = 12
write(1, " -> REC\n", 9 -> REC
) = 9
write(1, " -> Memory\n", 12 -> Memory
) = 12
write(1, " -> CSV\n", 9 -> CSV
) = 9
write(1, " -> GML\n", 9 -> GML
) = 9
write(1, " -> KML\n", 9 -> KML
) = 9
write(1, " -> OGDI\n", 10 -> OGDI
) = 10
exit_group(1) = ?
Process 8229 detached
[root at gis ~]#
