[Gdal-dev] struggling with ogrinfo and vmap data
Chapman, Martin
MChapman at sanz.com
Thu Dec 28 11:59:41 EST 2006
You need to compile gdal with support for OGDI. That requires
downloading and compiling the OGDI library from http://www.ogdi.org .
If you want a quick start I can put a zip of a built version on an ftp
site...as long as you are windows. Then you just need to change the
nmake.opt file to uncomment OGDI support and you will be good to go.
Martin Chapman
SANZ Inc.
Software Developer
http://www.earthwhere.com
W - 303.495.6326
C - 303.898.0397
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Bruce Bushby
Sent: Thursday, December 28, 2006 7:41 AM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] struggling with ogrinfo and vmap data
Hi
I've been struggling to query vmap data using ogrinfo and hoping
somebody
could point me in the right direction?
I have "cleaned" the vmap data so that ALL capitals have been converted
to
lower case.
This is my command and output:
[root at gis ~]# ogrinfo --debug on -ro
gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer
OGR: OGROpen(gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer) failed.
FAILURE:
Unable to open datasource
`gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the following drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> KML
-> OGDI
[root at gis ~]#
My setup/compilation is as follows (Fedora Core 6 [X86_64]):
expat-2.0.0
./configure;make install;ldconfig
zlib-1.2.3
./configure --shared --prefix=/usr/local; make install; ldconfig
proj-4.5.0
./configure; make install; ldconfig
ogdi-3.1.5
export TOPDIR=`pwd`
./configure --with-zlib --with-expat --with-proj; make install;
ldconfig
gdal-1.4.0beta2
./configure --with-ogdi=/usr/local; make install; ldconfig
I have also pasted the output of a strace in case it helps. Looking at
the strace, ogrinfo
does attempt to read the data:
"read(3, "\267\0\0\0L;Coverage Attribute Table;-"..., 4096) =
643"
Going through the strace, it looks for "gdalplugins"...which I don't
have?
Also, it tries to open a "cax" file which does not exist in my map data?
Any help or pointers would be much appreciated!
Regards
Bruce
STRACE OUTPUT:
[root at gis ~]# strace ogrinfo -ro
execve("/usr/local/bin/ogrinfo", ["ogrinfo", "-ro",
"gltp:/vrf/tmp/vmap0/v0noa/vmaplv"...], [/* 28 vars */]) = 0
brk(0) = 0x603000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0)
= 0x2b5481fe8000
uname({sys="Linux", node="gis.celtec.co.uk", ...}) = 0
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or
directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=172753, ...}) = 0
mmap(NULL, 172753, PROT_READ, MAP_PRIVATE, 3, 0) = 0x2b5481fe9000
close(3) = 0
open("/usr/local/lib/libgdal.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\6\16"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=4607087, ...}) = 0
= 0x2b5482014000
mmap(NULL, 6305160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54821e9000
mprotect(0x2b5482573000, 2093056, PROT_NONE) = 0
mmap(0x2b5482772000, 413696, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x389000) = 0x2b5482772000
mmap(0x2b54827d7000, 87432, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54827d7000
close(3) = 0
open("/usr/local/lib/libogdi31.so", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260m\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=150802, ...}) = 0
mmap(NULL, 2227928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54827ed000
mprotect(0x2b548280c000, 2097152, PROT_NONE) = 0
mmap(0x2b5482a0c000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5482a0c000
close(3) = 0
open("/usr/lib64/libgif.so.4", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\35\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=34552, ...}) = 0
mmap(NULL, 2129832, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5482a0d000
mprotect(0x2b5482a15000, 2093056, PROT_NONE) = 0
mmap(0x2b5482c14000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b5482c14000
close(3) = 0
open("/usr/lib64/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P5\0\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=139296, ...}) = 0
= 0x2b5482c15000
mmap(NULL, 2234544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5482c16000
mprotect(0x2b5482c37000, 2097152, PROT_NONE) = 0
mmap(0x2b5482e37000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x2b5482e37000
close(3) = 0
open("/usr/lib64/libtiff.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20v\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=365280, ...}) = 0
mmap(NULL, 2461640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5482e38000
mprotect(0x2b5482e8f000, 2093056, PROT_NONE) = 0
mmap(0x2b548308e000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x56000) = 0x2b548308e000
close(3) = 0
open("/usr/lib64/libpng12.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0H\0\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=147144, ...}) = 0
mmap(NULL, 2242312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5483091000
mprotect(0x2b54830b4000, 2097152, PROT_NONE) = 0
mmap(0x2b54832b4000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b54832b4000
close(3) = 0
open("/lib64/librt.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300#\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=50320, ...}) = 0
= 0x2b54832b5000
mmap(NULL, 2132968, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54832b6000
mprotect(0x2b54832be000, 2093056, PROT_NONE) = 0
mmap(0x2b54834bd000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b54834bd000
close(3) = 0
open("/usr/lib64/libcurl.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\257"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=249736, ...}) = 0
mmap(NULL, 2345608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54834bf000
mprotect(0x2b54834fa000, 2097152, PROT_NONE) = 0
mmap(0x2b54836fa000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x2b54836fa000
close(3) = 0
open("/usr/lib64/libgssapi_krb5.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000`\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=171336, ...}) = 0
mmap(NULL, 2266896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54836fc000
mprotect(0x2b5483725000, 2093056, PROT_NONE) = 0
mmap(0x2b5483924000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x2b5483924000
close(3) = 0
open("/usr/lib64/libkrb5.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 s\1\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=553008, ...}) = 0
= 0x2b5483926000
mmap(NULL, 2648352, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5483927000
mprotect(0x2b54839aa000, 2097152, PROT_NONE) = 0
mmap(0x2b5483baa000, 16384, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x83000) = 0x2b5483baa000
close(3) = 0
open("/usr/lib64/libk5crypto.so.3", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000U\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=150568, ...}) = 0
mmap(NULL, 2246920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5483bae000
mprotect(0x2b5483bd1000, 2097152, PROT_NONE) = 0
mmap(0x2b5483dd1000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b5483dd1000
close(3) = 0
open("/lib64/libcom_err.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\f\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=8000, ...}) = 0
mmap(NULL, 2103320, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5483dd3000
mprotect(0x2b5483dd5000, 2093056, PROT_NONE) = 0
mmap(0x2b5483fd4000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b5483fd4000
close(3) = 0
open("/lib64/libresolv.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3603\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=89792, ...}) = 0
= 0x2b5483fd5000
mmap(NULL, 2181864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5483fd6000
mprotect(0x2b5483fe7000, 2097152, PROT_NONE) = 0
mmap(0x2b54841e7000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x2b54841e7000
mmap(0x2b54841e9000, 6888, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54841e9000
close(3) = 0
open("/lib64/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\17\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=20520, ...}) = 0
mmap(NULL, 2109728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54841eb000
mprotect(0x2b54841ee000, 2093056, PROT_NONE) = 0
mmap(0x2b54843ed000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x2b54843ed000
close(3) = 0
open("/usr/lib64/libidn.so.11", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220/\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=202592, ...}) = 0
mmap(NULL, 2297840, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54843ef000
mprotect(0x2b5484420000, 2093056, PROT_NONE) = 0
mmap(0x2b548461f000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x2b548461f000
close(3) = 0
open("/lib64/libssl.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\"\1"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=299976, ...}) = 0
= 0x2b5484620000
mmap(NULL, 2395424, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5484621000
mprotect(0x2b5484664000, 2097152, PROT_NONE) = 0
mmap(0x2b5484864000, 24576, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x43000) = 0x2b5484864000
close(3) = 0
open("/lib64/libcrypto.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0d\5\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1324224, ...}) = 0
mmap(NULL, 3434488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b548486a000
mprotect(0x2b548498f000, 2093056, PROT_NONE) = 0
mmap(0x2b5484b8e000, 126976, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x124000) = 0x2b5484b8e000
mmap(0x2b5484bad000, 14328, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b5484bad000
close(3) = 0
open("/usr/local/lib/libz.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\36\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=118627, ...}) = 0
mmap(NULL, 2205160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5484bb1000
mprotect(0x2b5484bcc000, 2093056, PROT_NONE) = 0
mmap(0x2b5484dcb000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x2b5484dcb000
close(3) = 0
open("/usr/lib64/libstdc++.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \364\4\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=981840, ...}) = 0
= 0x2b5484dcc000
mmap(NULL, 3153696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5484dcd000
mprotect(0x2b5484eb4000, 2097152, PROT_NONE) = 0
mmap(0x2b54850b4000, 36864, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe7000) = 0x2b54850b4000
mmap(0x2b54850bd000, 73504, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54850bd000
close(3) = 0
open("/lib64/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260?\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=611880, ...}) = 0
mmap(NULL, 2629848, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54850cf000
mprotect(0x2b5485151000, 2093056, PROT_NONE) = 0
mmap(0x2b5485350000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x81000) = 0x2b5485350000
close(3) = 0
open("/lib64/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\37\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=54672, ...}) = 0
mmap(NULL, 2150376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5485352000
mprotect(0x2b548535f000, 2093056, PROT_NONE) = 0
mmap(0x2b548555e000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x2b548555e000
close(3) = 0
open("/lib64/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\333\1\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1672888, ...}) = 0
= 0x2b548555f000
mmap(NULL, 3461304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5485560000
mprotect(0x2b54856a4000, 2097152, PROT_NONE) = 0
mmap(0x2b54858a4000, 20480, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x144000) = 0x2b54858a4000
mmap(0x2b54858a9000, 16568, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54858a9000
close(3) = 0
open("/lib64/libexpat.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340;\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=141008, ...}) = 0
mmap(NULL, 2236256, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b54858ae000
mprotect(0x2b54858ce000, 2093056, PROT_NONE) = 0
mmap(0x2b5485acd000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5485acd000
close(3) = 0
open("/usr/local/lib/libproj.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\254\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=423295, ...}) = 0
mmap(NULL, 2473312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5485ad0000
mprotect(0x2b5485b29000, 2097152, PROT_NONE) = 0
mmap(0x2b5485d29000, 12288, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x59000) = 0x2b5485d29000
close(3) = 0
= 0x2b5485d2c000
open("/usr/lib64/libX11.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\377"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1093112, ...}) = 0
mmap(NULL, 3190376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5485d2d000
mprotect(0x2b5485e31000, 2097152, PROT_NONE) = 0
mmap(0x2b5486031000, 28672, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x104000) = 0x2b5486031000
close(3) = 0
open("/lib64/libpthread.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`X\0\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=138080, ...}) = 0
mmap(NULL, 2200432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5486038000
mprotect(0x2b548604d000, 2093056, PROT_NONE) = 0
mmap(0x2b548624c000, 8192, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x2b548624c000
mmap(0x2b548624e000, 13168, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b548624e000
close(3) = 0
open("/usr/lib64/libkrb5support.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\34\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=30088, ...}) = 0
= 0x2b5486252000
mmap(NULL, 2125392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5486253000
mprotect(0x2b548625a000, 2093056, PROT_NONE) = 0
mmap(0x2b5486459000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x2b5486459000
close(3) = 0
open("/usr/lib64/libXau.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\16\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=10064, ...}) = 0
mmap(NULL, 2105328, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b548645a000
mprotect(0x2b548645c000, 2093056, PROT_NONE) = 0
mmap(0x2b548665b000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b548665b000
close(3) = 0
open("/usr/lib64/libXdmcp.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\23\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=20136, ...}) = 0
= 0x2b548665c000
mmap(NULL, 2115384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b548665d000
mprotect(0x2b5486662000, 2093056, PROT_NONE) = 0
mmap(0x2b5486861000, 4096, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x2b5486861000
close(3) = 0
= 0x2b5486862000
= 0x2b5486863000
= 0x2b5486864000
arch_prctl(ARCH_SET_FS, 0x2b5486863ae0) = 0
mprotect(0x2b548624c000, 4096, PROT_READ) = 0
mprotect(0x2b54858a4000, 16384, PROT_READ) = 0
mprotect(0x2b5485350000, 4096, PROT_READ) = 0
mprotect(0x2b54850b4000, 24576, PROT_READ) = 0
mprotect(0x2b54843ed000, 4096, PROT_READ) = 0
mprotect(0x2b54841e7000, 4096, PROT_READ) = 0
mprotect(0x2b54834bd000, 4096, PROT_READ) = 0
mprotect(0x2b54821e7000, 4096, PROT_READ) = 0
munmap(0x2b5481fe9000, 172753) = 0
set_tid_address(0x2b5486863b70) = 8229
syscall_273(0x2b5486863b80, 0x18, 0x7fff28ad9418, 0x2b5481fce4a0,
0x2b5486863ae0, 0x2b5481fe82b8, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3,
0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3,
0x3, 0x3, 0x3, 0x3) = 0
rt_sigaction(SIGRTMIN, {0x2b548603d4a0, [], SA_RESTORER|SA_SIGINFO,
0x2b5486045de0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x2b548603d3f0, [],
SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x2b5486045de0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) =
0
futex(0x2b54850bec88, FUTEX_WAKE, 2147483647) = 0
brk(0) = 0x603000
brk(0x624000) = 0x624000
open("/usr/local/lib/gdalplugins", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = -1
ENOENT (No such file or directory)
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9130) = -1
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90d0) = -1
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90b0) = -1
open("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", O_RDONLY) = -1 ENOENT
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9100) = -1
stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9120) = -1
futex(0x2b54843ee10c, FUTEX_WAKE, 2147483647) = 0
close(3) = 0
open("/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or
directory)
open("/lib64/tls/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/lib64/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/lib64/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or
directory)
open("/lib64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/usr/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file
or directory)
open("/usr/lib64/tls/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/usr/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib64/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/usr/lib64/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or
directory)
open("/usr/lib64/vrf", O_RDONLY) = -1 ENOENT (No such file or
directory)
stat("/usr/lib64", {st_mode=S_IFDIR|0755, st_size=98304, ...}) = 0
close(3) = 0
open("/usr/local/lib/libvrf.so", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`S\0\0\0"...,
832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=195623, ...}) = 0
mmap(NULL, 2276864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
0) = 0x2b5486865000
mprotect(0x2b5486889000, 2097152, PROT_NONE) = 0
mmap(0x2b5486a89000, 32768, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x2b5486a89000
close(3) = 0
mmap(NULL, 253952, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0) = 0x2b5482015000
access("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", F_OK) = 0
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 3
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
close(4) = 0
fstat(3, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
= 0x2b5482053000
read(3, "\267\0\0\0L;Coverage Attribute Table;-"..., 4096) = 643
mmap(NULL, 8017316959253172224, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = -1 ENOMEM (Cannot allocate memory)
brk(0x6f433b4c0063d000) = 0x624000
mmap(NULL, 8017316959253307392, PROT_READ|PROT_WRITE,
mmap(NULL, 134217728, PROT_NONE,
MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0x2b5486a91000
munmap(0x2b5486a91000, 22474752) = 0
munmap(0x2b548c000000, 44634112) = 0
mprotect(0x2b5488000000, 135168, PROT_READ|PROT_WRITE) = 0
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax", O_RDONLY) = -1 ENOENT (No
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.", O_RDONLY) = -1 ENOENT (No
open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.;1", O_RDONLY) = -1 ENOENT (No
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX", O_RDONLY) = -1 ENOENT (No
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.", O_RDONLY) = -1 ENOENT (No
open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.;1", O_RDONLY) = -1 ENOENT (No
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX", O_RDONLY) = -1 ENOENT (No
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.", O_RDONLY) = -1 ENOENT (No
open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.;1", O_RDONLY) = -1 ENOENT (No
close(3) = 0
munmap(0x2b5482053000, 4096) = 0
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 2), ...}) = 0
= 0x2b5482053000
write(1, "FAILURE:\n", 9FAILURE:
) = 9
write(1, "Unable to open datasource `gltp:"..., 97Unable to open
datasource `gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the following
drivers.
) = 97
write(1, " -> ESRI Shapefile\n", 20 -> ESRI Shapefile
) = 20
write(1, " -> MapInfo File\n", 18 -> MapInfo File
) = 18
write(1, " -> UK .NTF\n", 13 -> UK .NTF
) = 13
write(1, " -> SDTS\n", 10 -> SDTS
) = 10
write(1, " -> TIGER\n", 11 -> TIGER
) = 11
write(1, " -> S57\n", 9 -> S57
) = 9
write(1, " -> DGN\n", 9 -> DGN
) = 9
write(1, " -> VRT\n", 9 -> VRT
) = 9
write(1, " -> AVCBin\n", 12 -> AVCBin
) = 12
write(1, " -> REC\n", 9 -> REC
) = 9
write(1, " -> Memory\n", 12 -> Memory
) = 12
write(1, " -> CSV\n", 9 -> CSV
) = 9
write(1, " -> GML\n", 9 -> GML
) = 9
write(1, " -> KML\n", 9 -> KML
) = 9
write(1, " -> OGDI\n", 10 -> OGDI
) = 10
exit_group(1) = ?
Process 8229 detached
[root at gis ~]#
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
