[Gdal-dev] struggling with ogrinfo and vmap data
Chapman, Martin MChapman at sanz.com
Thu Dec 28 13:17:52 EST 2006
Bruce,
Whoops, the location for OGDI is http://ogdi.sourceforge.net/
Also, see
http://www.pcigeomatics.com/cgi-bin/pcihlp/GDB%7CSupported+File+Formats%
7COGDI+(Open+Geospatial+Datastore+Interface) for a better description on
how to query OGDI layers.
Martin Chapman
SANZ Inc.
Software Developer
http://www.earthwhere.com
W - 303.495.6326
C  - 303.898.0397
-----Original Message-----
From: Bruce Bushby [mailto:bruce.bushby at rmsaudio.com]
Sent: Thursday, December 28, 2006 10:53 AM
To: Chapman, Martin
Subject: RE: [Gdal-dev] struggling with ogrinfo and vmap data
Hi Martin
Thanks for getting back to me, I've been pulling my hair for the past 3
days so do appreciate the input.
I have compiled gdal with ogdi-3.1.5, my compile process was as follows:
	expat-2.0.0
	./configure;make install;ldconfig
	zlib-1.2.3
	./configure --shared --prefix=/usr/local; make install; ldconfig
	proj-4.5.0
	./configure; make install; ldconfig
	ogdi-3.1.5
	export TOPDIR=`pwd`
	./configure --with-zlib=/usr/local --with-expat=/usr/local
--with-proj=/usr/local; make install;ldconfig
	gdal-1.4.0beta2
	./configure --with-ogdi=/usr/local; make install; ldconfig
Everything compiles fine and the resulting binaries all seem to
work....it's just that ogrinfo won't read my vmap data :)
I'm busy downloading Fedora Core 6 (32bit) as my current platform is
Fedora Core 6 (64bit).
www.ogdi.org doesn't seem to exist, I got my ogdi from sourceforge.
Thanks again, will send an update if/when I get it working.
Regards
Bruce
On Thu, 2006-12-28 at 09:59 -0700, Chapman, Martin wrote:
> You need to compile gdal with support for OGDI.  That requires
> downloading and compiling the OGDI library from http://www.ogdi.org .
> If you want a quick start I can put a zip of a built version on an ftp
> site...as long as you are windows.  Then you just need to change the
> nmake.opt file to uncomment OGDI support and you will be good to go.
> Martin Chapman
> SANZ Inc.
> Software Developer
> W - 303.495.6326
> C  - 303.898.0397
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Bruce Bushby
> Sent: Thursday, December 28, 2006 7:41 AM
> To: gdal-dev at lists.maptools.org
> Subject: [Gdal-dev] struggling with ogrinfo and vmap data
> Hi
> I've been struggling to query vmap data using ogrinfo and hoping
> somebody
> could point me in the right direction?
> I have "cleaned" the vmap data so that ALL capitals have been
converted
> to
> lower case.
> This is my command and output:
> 	[root at gis ~]# ogrinfo --debug on -ro
> gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer
> 	OGR: OGROpen(gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer) failed.
> 	FAILURE:
> 	Unable to open datasource
> `gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the following drivers.
>   	-> ESRI Shapefile
>   	-> MapInfo File
>   	-> UK .NTF
>   	-> SDTS
>   	-> TIGER
>   	-> S57
>   	-> DGN
>   	-> VRT
>   	-> AVCBin
>   	-> REC
>   	-> Memory
>   	-> CSV
>   	-> GML
>   	-> KML
>   	-> OGDI
> 	[root at gis ~]#
> My setup/compilation is as follows (Fedora Core 6 [X86_64]):
> 	expat-2.0.0
> 	zlib-1.2.3
> 	proj-4.5.0
> 	ogdi-3.1.5
> 	export TOPDIR=`pwd`
> 	./configure --with-zlib --with-expat --with-proj; make install;
> ldconfig
> 	gdal-1.4.0beta2
> I have also pasted the output of a strace in case it helps. Looking at
> the strace, ogrinfo
> does attempt to read the data:
> 	"read(3, "\267\0\0\0L;Coverage Attribute Table;-"..., 4096) =
> 643"
> Going through the strace, it looks for "gdalplugins"...which I don't
> have?
> Also, it tries to open a "cax" file which does not exist in my map
data?
> Any help or pointers would be much appreciated!
> Regards
> Bruce
> STRACE OUTPUT:
> [root at gis ~]# strace ogrinfo -ro
> execve("/usr/local/bin/ogrinfo", ["ogrinfo", "-ro",
> "gltp:/vrf/tmp/vmap0/v0noa/vmaplv"...], [/* 28 vars */]) = 0
> brk(0)                                  = 0x603000
> mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0)
> = 0x2b5481fe8000
> uname({sys="Linux", node="gis.celtec.co.uk", ...}) = 0
> access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or
> directory)
> open("/etc/ld.so.cache", O_RDONLY)      = 3
> fstat(3, {st_mode=S_IFREG|0644, st_size=172753, ...}) = 0
> mmap(NULL, 172753, PROT_READ, MAP_PRIVATE, 3, 0) = 0x2b5481fe9000
> close(3)                                = 0
> open("/usr/local/lib/libgdal.so.1", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\6\16"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=4607087, ...}) = 0
0)
> = 0x2b5482014000
> mmap(NULL, 6305160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54821e9000
> mprotect(0x2b5482573000, 2093056, PROT_NONE) = 0
> mmap(0x2b5482772000, 413696, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x389000) = 0x2b5482772000
> mmap(0x2b54827d7000, 87432, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54827d7000
> close(3)                                = 0
> open("/usr/local/lib/libogdi31.so", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260m\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=150802, ...}) = 0
> mmap(NULL, 2227928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54827ed000
> mprotect(0x2b548280c000, 2097152, PROT_NONE) = 0
> mmap(0x2b5482a0c000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5482a0c000
> close(3)                                = 0
> open("/usr/lib64/libgif.so.4", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\35\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=34552, ...}) = 0
> mmap(NULL, 2129832, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5482a0d000
> mprotect(0x2b5482a15000, 2093056, PROT_NONE) = 0
> mmap(0x2b5482c14000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b5482c14000
> close(3)                                = 0
> open("/usr/lib64/libjpeg.so.62", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P5\0\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=139296, ...}) = 0
0)
> = 0x2b5482c15000
> mmap(NULL, 2234544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5482c16000
> mprotect(0x2b5482c37000, 2097152, PROT_NONE) = 0
> mmap(0x2b5482e37000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x2b5482e37000
> close(3)                                = 0
> open("/usr/lib64/libtiff.so.3", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20v\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=365280, ...}) = 0
> mmap(NULL, 2461640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5482e38000
> mprotect(0x2b5482e8f000, 2093056, PROT_NONE) = 0
> mmap(0x2b548308e000, 12288, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x56000) = 0x2b548308e000
> close(3)                                = 0
> open("/usr/lib64/libpng12.so.0", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0H\0\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=147144, ...}) = 0
> mmap(NULL, 2242312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5483091000
> mprotect(0x2b54830b4000, 2097152, PROT_NONE) = 0
> mmap(0x2b54832b4000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b54832b4000
> close(3)                                = 0
> open("/lib64/librt.so.1", O_RDONLY)     = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300#\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=50320, ...}) = 0
0)
> = 0x2b54832b5000
> mmap(NULL, 2132968, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54832b6000
> mprotect(0x2b54832be000, 2093056, PROT_NONE) = 0
> mmap(0x2b54834bd000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x2b54834bd000
> close(3)                                = 0
> open("/usr/lib64/libcurl.so.3", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\257"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=249736, ...}) = 0
> mmap(NULL, 2345608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54834bf000
> mprotect(0x2b54834fa000, 2097152, PROT_NONE) = 0
> mmap(0x2b54836fa000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x2b54836fa000
> close(3)                                = 0
> open("/usr/lib64/libgssapi_krb5.so.2", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000`\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=171336, ...}) = 0
> mmap(NULL, 2266896, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54836fc000
> mprotect(0x2b5483725000, 2093056, PROT_NONE) = 0
> mmap(0x2b5483924000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x2b5483924000
> close(3)                                = 0
> open("/usr/lib64/libkrb5.so.3", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 s\1\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=553008, ...}) = 0
0)
> = 0x2b5483926000
> mmap(NULL, 2648352, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5483927000
> mprotect(0x2b54839aa000, 2097152, PROT_NONE) = 0
> mmap(0x2b5483baa000, 16384, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x83000) = 0x2b5483baa000
> close(3)                                = 0
> open("/usr/lib64/libk5crypto.so.3", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000U\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=150568, ...}) = 0
> mmap(NULL, 2246920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5483bae000
> mprotect(0x2b5483bd1000, 2097152, PROT_NONE) = 0
> mmap(0x2b5483dd1000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x2b5483dd1000
> close(3)                                = 0
> open("/lib64/libcom_err.so.2", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\f\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=8000, ...}) = 0
> mmap(NULL, 2103320, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5483dd3000
> mprotect(0x2b5483dd5000, 2093056, PROT_NONE) = 0
> mmap(0x2b5483fd4000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b5483fd4000
> close(3)                                = 0
> open("/lib64/libresolv.so.2", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3603\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=89792, ...}) = 0
0)
> = 0x2b5483fd5000
> mmap(NULL, 2181864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5483fd6000
> mprotect(0x2b5483fe7000, 2097152, PROT_NONE) = 0
> mmap(0x2b54841e7000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x2b54841e7000
> mmap(0x2b54841e9000, 6888, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54841e9000
> close(3)                                = 0
> open("/lib64/libdl.so.2", O_RDONLY)     = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\17\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=20520, ...}) = 0
> mmap(NULL, 2109728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54841eb000
> mprotect(0x2b54841ee000, 2093056, PROT_NONE) = 0
> mmap(0x2b54843ed000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x2b54843ed000
> close(3)                                = 0
> open("/usr/lib64/libidn.so.11", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220/\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=202592, ...}) = 0
> mmap(NULL, 2297840, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54843ef000
> mprotect(0x2b5484420000, 2093056, PROT_NONE) = 0
> mmap(0x2b548461f000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x2b548461f000
> close(3)                                = 0
> open("/lib64/libssl.so.6", O_RDONLY)    = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\"\1"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=299976, ...}) = 0
0)
> = 0x2b5484620000
> mmap(NULL, 2395424, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5484621000
> mprotect(0x2b5484664000, 2097152, PROT_NONE) = 0
> mmap(0x2b5484864000, 24576, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x43000) = 0x2b5484864000
> close(3)                                = 0
> open("/lib64/libcrypto.so.6", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0d\5\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=1324224, ...}) = 0
> mmap(NULL, 3434488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b548486a000
> mprotect(0x2b548498f000, 2093056, PROT_NONE) = 0
> mmap(0x2b5484b8e000, 126976, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x124000) = 0x2b5484b8e000
> mmap(0x2b5484bad000, 14328, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b5484bad000
> close(3)                                = 0
> open("/usr/local/lib/libz.so.1", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\36\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=118627, ...}) = 0
> mmap(NULL, 2205160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5484bb1000
> mprotect(0x2b5484bcc000, 2093056, PROT_NONE) = 0
> mmap(0x2b5484dcb000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x2b5484dcb000
> close(3)                                = 0
> open("/usr/lib64/libstdc++.so.6", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \364\4\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=981840, ...}) = 0
0)
> = 0x2b5484dcc000
> mmap(NULL, 3153696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5484dcd000
> mprotect(0x2b5484eb4000, 2097152, PROT_NONE) = 0
> mmap(0x2b54850b4000, 36864, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe7000) = 0x2b54850b4000
> mmap(0x2b54850bd000, 73504, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54850bd000
> close(3)                                = 0
> open("/lib64/libm.so.6", O_RDONLY)      = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260?\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=611880, ...}) = 0
> mmap(NULL, 2629848, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54850cf000
> mprotect(0x2b5485151000, 2093056, PROT_NONE) = 0
> mmap(0x2b5485350000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x81000) = 0x2b5485350000
> close(3)                                = 0
> open("/lib64/libgcc_s.so.1", O_RDONLY)  = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\37\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=54672, ...}) = 0
> mmap(NULL, 2150376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5485352000
> mprotect(0x2b548535f000, 2093056, PROT_NONE) = 0
> mmap(0x2b548555e000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x2b548555e000
> close(3)                                = 0
> open("/lib64/libc.so.6", O_RDONLY)      = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\333\1\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=1672888, ...}) = 0
0)
> = 0x2b548555f000
> mmap(NULL, 3461304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5485560000
> mprotect(0x2b54856a4000, 2097152, PROT_NONE) = 0
> mmap(0x2b54858a4000, 20480, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x144000) = 0x2b54858a4000
> mmap(0x2b54858a9000, 16568, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b54858a9000
> close(3)                                = 0
> open("/lib64/libexpat.so.0", O_RDONLY)  = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340;\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=141008, ...}) = 0
> mmap(NULL, 2236256, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b54858ae000
> mprotect(0x2b54858ce000, 2093056, PROT_NONE) = 0
> mmap(0x2b5485acd000, 12288, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x2b5485acd000
> close(3)                                = 0
> open("/usr/local/lib/libproj.so.0", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\254\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=423295, ...}) = 0
> mmap(NULL, 2473312, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5485ad0000
> mprotect(0x2b5485b29000, 2097152, PROT_NONE) = 0
> mmap(0x2b5485d29000, 12288, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x59000) = 0x2b5485d29000
> close(3)                                = 0
0)
> = 0x2b5485d2c000
> open("/usr/lib64/libX11.so.6", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\377"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=1093112, ...}) = 0
> mmap(NULL, 3190376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5485d2d000
> mprotect(0x2b5485e31000, 2097152, PROT_NONE) = 0
> mmap(0x2b5486031000, 28672, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x104000) = 0x2b5486031000
> close(3)                                = 0
> open("/lib64/libpthread.so.0", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`X\0\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=138080, ...}) = 0
> mmap(NULL, 2200432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5486038000
> mprotect(0x2b548604d000, 2093056, PROT_NONE) = 0
> mmap(0x2b548624c000, 8192, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x2b548624c000
> mmap(0x2b548624e000, 13168, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b548624e000
> close(3)                                = 0
> open("/usr/lib64/libkrb5support.so.0", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\34\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=30088, ...}) = 0
0)
> = 0x2b5486252000
> mmap(NULL, 2125392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5486253000
> mprotect(0x2b548625a000, 2093056, PROT_NONE) = 0
> mmap(0x2b5486459000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x2b5486459000
> close(3)                                = 0
> open("/usr/lib64/libXau.so.6", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\16\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=10064, ...}) = 0
> mmap(NULL, 2105328, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b548645a000
> mprotect(0x2b548645c000, 2093056, PROT_NONE) = 0
> mmap(0x2b548665b000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x2b548665b000
> close(3)                                = 0
> open("/usr/lib64/libXdmcp.so.6", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\23\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=20136, ...}) = 0
0)
> = 0x2b548665c000
> mmap(NULL, 2115384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b548665d000
> mprotect(0x2b5486662000, 2093056, PROT_NONE) = 0
> mmap(0x2b5486861000, 4096, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x2b5486861000
> close(3)                                = 0
0)
> = 0x2b5486862000
0)
> = 0x2b5486863000
0)
> = 0x2b5486864000
> arch_prctl(ARCH_SET_FS, 0x2b5486863ae0) = 0
> mprotect(0x2b548624c000, 4096, PROT_READ) = 0
> mprotect(0x2b54858a4000, 16384, PROT_READ) = 0
> mprotect(0x2b5485350000, 4096, PROT_READ) = 0
> mprotect(0x2b54850b4000, 24576, PROT_READ) = 0
> mprotect(0x2b54843ed000, 4096, PROT_READ) = 0
> mprotect(0x2b54841e7000, 4096, PROT_READ) = 0
> mprotect(0x2b54834bd000, 4096, PROT_READ) = 0
> mprotect(0x2b54821e7000, 4096, PROT_READ) = 0
> munmap(0x2b5481fe9000, 172753)          = 0
> set_tid_address(0x2b5486863b70)         = 8229
> syscall_273(0x2b5486863b80, 0x18, 0x7fff28ad9418, 0x2b5481fce4a0,
> 0x2b5486863ae0, 0x2b5481fe82b8, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3,
0x3,
> 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3, 0x3,
> 0x3, 0x3, 0x3, 0x3) = 0
> rt_sigaction(SIGRTMIN, {0x2b548603d4a0, [], SA_RESTORER|SA_SIGINFO,
> 0x2b5486045de0}, NULL, 8) = 0
> rt_sigaction(SIGRT_1, {0x2b548603d3f0, [],
> SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x2b5486045de0}, NULL, 8) = 0
> rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
> getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY})
> 0
> futex(0x2b54850bec88, FUTEX_WAKE, 2147483647) = 0
> brk(0)                                  = 0x603000
> brk(0x624000)                           = 0x624000
> open("/usr/local/lib/gdalplugins", O_RDONLY|O_NONBLOCK|O_DIRECTORY) =
-1
> ENOENT (No such file or directory)
> stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9130) = -1
> stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90d0) = -1
> stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad90b0) = -1
> open("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", O_RDONLY) = -1 ENOENT
> stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9100) = -1
> stat("gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer", 0x7fff28ad9120) = -1
> futex(0x2b54843ee10c, FUTEX_WAKE, 2147483647) = 0
> close(3)                                = 0
> open("/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
> directory)
> stat("/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or
> directory)
> open("/lib64/tls/vrf", O_RDONLY)        = -1 ENOENT (No such file or
> directory)
> stat("/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
> open("/lib64/x86_64/vrf", O_RDONLY)     = -1 ENOENT (No such file or
> directory)
> stat("/lib64/x86_64", 0x7fff28ad87e0)   = -1 ENOENT (No such file or
> directory)
> open("/lib64/vrf", O_RDONLY)            = -1 ENOENT (No such file or
> directory)
> stat("/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
> open("/usr/lib64/tls/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file
or
> directory)
> stat("/usr/lib64/tls/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such
file
> or directory)
> open("/usr/lib64/tls/vrf", O_RDONLY)    = -1 ENOENT (No such file or
> directory)
> stat("/usr/lib64/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
> open("/usr/lib64/x86_64/vrf", O_RDONLY) = -1 ENOENT (No such file or
> directory)
> stat("/usr/lib64/x86_64", 0x7fff28ad87e0) = -1 ENOENT (No such file or
> directory)
> open("/usr/lib64/vrf", O_RDONLY)        = -1 ENOENT (No such file or
> directory)
> stat("/usr/lib64", {st_mode=S_IFDIR|0755, st_size=98304, ...}) = 0
> close(3)                                = 0
> open("/usr/local/lib/libvrf.so", O_RDONLY) = 3
> read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`S\0\0\0"...,
> 832) = 832
> fstat(3, {st_mode=S_IFREG|0755, st_size=195623, ...}) = 0
> mmap(NULL, 2276864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3,
> 0) = 0x2b5486865000
> mprotect(0x2b5486889000, 2097152, PROT_NONE) = 0
> mmap(0x2b5486a89000, 32768, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x2b5486a89000
> close(3)                                = 0
> mmap(NULL, 253952, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS,
-1,
> 0) = 0x2b5482015000
> access("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", F_OK) = 0
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 3
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/cat", O_RDONLY) = 4
> fstat(4, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
> close(4)                                = 0
> fstat(3, {st_mode=S_IFREG|0755, st_size=643, ...}) = 0
0)
> = 0x2b5482053000
> read(3, "\267\0\0\0L;Coverage Attribute Table;-"..., 4096) = 643
> mmap(NULL, 8017316959253172224, PROT_READ|PROT_WRITE,
> MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = -1 ENOMEM (Cannot allocate memory)
> brk(0x6f433b4c0063d000)                 = 0x624000
> mmap(NULL, 8017316959253307392, PROT_READ|PROT_WRITE,
> mmap(NULL, 134217728, PROT_NONE,
> MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0x2b5486a91000
> munmap(0x2b5486a91000, 22474752)        = 0
> munmap(0x2b548c000000, 44634112)        = 0
> mprotect(0x2b5488000000, 135168, PROT_READ|PROT_WRITE) = 0
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax", O_RDONLY) = -1 ENOENT (No
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.", O_RDONLY) = -1 ENOENT (No
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/cax.;1", O_RDONLY) = -1 ENOENT
(No
(No
> open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX", O_RDONLY) = -1 ENOENT (No
> open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.", O_RDONLY) = -1 ENOENT (No
> open("/tmp/VMAP0/V0NOA/VMAPLV0/NOAMER/CAX.;1", O_RDONLY) = -1 ENOENT
(No
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX", O_RDONLY) = -1 ENOENT (No
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.", O_RDONLY) = -1 ENOENT (No
> open("/tmp/vmap0/v0noa/vmaplv0/noamer/caX.;1", O_RDONLY) = -1 ENOENT
(No
(No
(No
> close(3)                                = 0
> munmap(0x2b5482053000, 4096)            = 0
> fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 2), ...}) = 0
0)
> = 0x2b5482053000
> write(1, "FAILURE:\n", 9FAILURE:
> )               = 9
> write(1, "Unable to open datasource `gltp:"..., 97Unable to open
> datasource `gltp:/vrf/tmp/vmap0/v0noa/vmaplv0/noamer' with the
following
> drivers.
> ) = 97
> write(1, "  -> ESRI Shapefile\n", 20  -> ESRI Shapefile
> )   = 20
> write(1, "  -> MapInfo File\n", 18  -> MapInfo File
> )     = 18
> write(1, "  -> UK .NTF\n", 13  -> UK .NTF
> )          = 13
> write(1, "  -> SDTS\n", 10  -> SDTS
> )             = 10
> write(1, "  -> TIGER\n", 11  -> TIGER
> )            = 11
> write(1, "  -> S57\n", 9  -> S57
> )               = 9
> write(1, "  -> DGN\n", 9  -> DGN
> )               = 9
> write(1, "  -> VRT\n", 9  -> VRT
> )               = 9
> write(1, "  -> AVCBin\n", 12  -> AVCBin
> )           = 12
> write(1, "  -> REC\n", 9  -> REC
> )               = 9
> write(1, "  -> Memory\n", 12  -> Memory
> )           = 12
> write(1, "  -> CSV\n", 9  -> CSV
> )               = 9
> write(1, "  -> GML\n", 9  -> GML
> )               = 9
> write(1, "  -> KML\n", 9  -> KML
> )               = 9
> write(1, "  -> OGDI\n", 10  -> OGDI
> )             = 10
> exit_group(1)                           = ?
> Process 8229 detached
> [root at gis ~]#
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
