[Gdal-dev] ENVISAT data comes out left-right fliped
Julien Demaria
dem at acri-st.fr
Fri Feb 3 03:36:44 EST 2006
Joaquim,
This isn't a bug.
MERIS Envisat files are geolocated using a GCPs list (in fact one GCP
every 16 pixels). In the swath the file is left-right fliped, but it's
the specifications. If you want apply the GCPs projection and then flip
LR the file, you should use the gdalwarp GDAL utility:
gdalwarp MER_RR__1_Mediterranean.n1 MER_RR__1_Mediterranean.tif
(tested on Linux with FWTools-linux-1.0.0a7).
I've successfully viewed your file using FWTools OpenEV (FWTools1.0.0a8
on Windows). With it you can directly display (unflipped) your .n1 file
since OpenEV reproject on-the-fly the file using GCPs :)
Regards,
Julien
jluis a écrit :
>> Can you provide a pointer to a dataset that demonstrates
>> this, and details on how you came to the conclusion? This
>> should all be submitted in bugzilla.
> Frank,
> I got this file from a tutorial of Bilko
> (http://www.noc.soton.ac.uk/bilko/)
> Biko opens it correctly but my code that reads gdal
> recognized formats into matlab shows it "fliplr"
> The same happens when we use gdal_translate
> gdal_translate.exe -b 5 MER_RR__1_Mediterranean.n1 lixo.tif
> Its not obvious that the image is flipped because it's
> a bit dark, but you can see that Italy is flipped.
> ftp.ualg.pt/users/jluis/MER_RR__1_Mediterranean.zip
> Joaquim
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
