[Gdal-dev] ENVISAT data comes out left-right fliped
Frank Warmerdam
warmerdam at pobox.com
Mon Feb 6 19:41:01 EST 2006
On 2/3/06, Julien Demaria <dem at acri-st.fr> wrote:
> Joaquim,
> This isn't a bug.
> MERIS Envisat files are geolocated using a GCPs list (in fact one GCP
> every 16 pixels). In the swath the file is left-right fliped, but it's
> the specifications. If you want apply the GCPs projection and then flip
> LR the file, you should use the gdalwarp GDAL utility:
> gdalwarp MER_RR__1_Mediterranean.n1 MER_RR__1_Mediterranean.tif
> (tested on Linux with FWTools-linux-1.0.0a7).
> I've successfully viewed your file using FWTools OpenEV (FWTools1.0.0a8
> on Windows). With it you can directly display (unflipped) your .n1 file
> since OpenEV reproject on-the-fly the file using GCPs :)
Joaquim,
Julien is dead-on in his analysis. The images are
stored in a manner related to how they are collected,
but the geolocation info (GCPs) should allow you to
warp the image to north up if that is what you need.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
