[Gdal-dev] ECW small problem
Ivan Mjartan
ivan.mjartan at geovap.cz
Fri Feb 3 10:37:32 EST 2006
Hi all,
I have one question about minimum size of ECW raster
I tried create small ecw files and I tested that is no possible create smaller raster than 130*130px.
So what is possible minimum size of ECW?
I tried use gdal_translate.exe to create ecw from bitmap (Windows Device Independent Bitmap) 1505*130px and I got this error
ERROR 4: File c:\temp\testGdalAPP\t_2_2.ecw has unsupported number of bits per pixel.
What it means?
I don't understand because when I tried use gdal_translate.exe to create ecw from 3000*130 px bitmap(Windows Device Independent Bitmap) everything was fine.
Can somebody explain relation ECW <-> raster width and height
I am using gdal 13 and ECW SDK 3.3
Thank you very much
Ivan Mjartan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060203/4704da2c/attachment.html
