[Gdal-dev] ECW small problem
Tom Lynch
tflynch at gmail.com
Sun Feb 5 21:08:52 EST 2006
On 2/3/06, Ivan Mjartan <ivan.mjartan at geovap.cz> wrote:
> Hi all,
> I have one question about minimum size of ECW raster
> I tried create small ecw files and I tested that is no possible create
> smaller raster than 130*130px.
> So what is possible minimum size of ECW?
<snip>
Ivan,
ECW files have a minimum size of 128 x 128 pixels. This is due to
certain assumptions made by the encoder. Of course, given the
application area of the format (large imagery) this isn't much of a
limitation :-)
JPEG 2000 files don't have any such size restriction and can be as
small as 1x1 pixel.
I can't comment on the error you received from GDAL, except to state
that ECW files only ever use 8 bits per component per pixel (all data
is stored as unsigned 8 bit integers internally), so it seems likely
that it's erroneous.
Tom.
Tom Lynch
Development, ER Mapper
Phone: +61 8 93882900
Fax: +61 8 93882901
Email: tom.lynch at ermapper.com
Web: http://www.ermapper.com
Forums: http://forum.ermapper.com
