[Gdal-dev] ECW File open failed
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 7 15:09:24 EST 2006
Ken,
I think RC2 was released today
(http://www.ermapper.com/downloads/download_view.aspx?PRODUCT_VERSION_ID=288
Brent Fraser
GeoAnalytic Inc
Calgary, Alberta, Canada
----- Original Message -----
To: "GDAL" <gdal-dev at lists.maptools.org>
Sent: Tuesday, February 07, 2006 12:40 PM
Subject: Re: [Gdal-dev] ECW File open failed
> Ok, I've traced through gdalinfo. For anyone who's interested I found
> that gdb seems to get stuck in libecwj2-3.3/Source/C/NCSUtil/mutex.c in
> the function NCSMutexEnd:265 with the call to
> pthread_mutex_unlock(&(pMutex->m));
> After that point I get a
> Cannot access memory at 0x7fffffff4fb0
> and gdb won't go on. I'm not very knowledgable with pthreads, so I'm not
> sure what else I can do at this point. Since it seems like a libecw
> issue at this point so I'm going to list it on the ecwsdk 3.3RC1 feedback
> page. Unless any pthread guru's have any advice, I guess GDAL/ECW will
> have to go onto the back burner until ecwsdk 3.3rc2.
> Ken
> On Tue, 7 Feb 2006, Frank Warmerdam wrote:
> > On 2/7/06, Ken Sewell <sewell at dramail.com> wrote:
> > > Yes, "gdalinfo --formats" does list "ECW (rw)"
> > > I went ahead and downloaded the 3.3 RC1 and tried it on my 32-bit and
my
> > > 64-bit. gdalinfo on both machines show ECW in the formats list. ECW
on
> > > the 32-bit seems to work, same error on the 64-bit. The examples
> > > included with ecwsdk3.3rc1 do run on the 64-bit system. I'm trying to
> > > dig further. Is there an easy way to build a debug version of gdal?
I
> > > haven't found a config option or a makefile target to do this yet.
> > Ken,
> > How to build GDAL in debug mode is a closely guarded secret.
> > But if you promise not to tell anyone else, I'll pass it on.
> > Set the CFG environment variable to debug before building and
> > the debug options will be used.
> > eg.
> > $ export CFG=debug
> > $ make
> > Remember, it's secret. I do this in a completely nonstandard
> > way to ensure no one but me (and now you) can debug GDAL.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
