[Gdal-dev] OGRGeometry::Contains speed issue
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Feb  8 16:07:23 EST 2006
On 2/8/06, Rob McCulley <RMcCulley at county24.com> wrote:
> Hi all,
> I've got a python script that runs through a bunch of shapefiles, performs an OGRGeometry::Transform on them, adds a couple of attributes, and merges them all into one final shapefile.  All told it opens 76 shapefiles containing a total of ~18,000 polygons.  It performs this in about 10 minutes.
> My area of interest is an irregular area which contains ~16,000 of the polygons. I added in a couple of lines to the script to check if the polygon was in the aoi, and set an attribute accordingly:
> point = newGeom.Centroid()
> aoiTest = aoiGeom.Contains(point)
> if aoiTest == 1:
>         aoiVal = 1
> else:
>         aoiVal = 0
> There shouldn't ever be a situation where a polygon will cross the aoi boundary, but I use a centroid for the Contains, just in case it isn't perfect.
> The problem I'm having is this makes things a lot slower.  The first run through after adding those lines of code was ~17 hours (At the end the script outputs the run time in seconds).  For my purposes, 17 hours is too long.  I know that the aoi polygon is quite complex (~4000 vertices), and that probably slows things down a bit, but that much?  Am I missing something, or is there a better way of doing this?
Rob,
It might be nice to determine if the it is the Contains
operation, or the Centroid which is expensive. I suspect
it is the contains, but I'm not sure.
It might make sense to setup a much similar, but slightly
smaller AOI and first do the contains test against that.
Then do the test against the whole AOI if the item isn't
trivially contained in the simplified AOI.  That should reduce
the cost of the Contains operation alot.
But we you really need to do is preserve the spatial index
thingy that GEOS computes internally for the AOI from
test to test.  There is no way to do that through OGR.
In fact, I don't know how to do it directly with GEOS either
but I gather it is possible with some degree of fiddling.
Various other hacky solutions which roughly boil down to
maintaining your own course spatial index could also be
applied but will substantially complicate your script.
Modulo this particular issue, I am pleased that ogr and python
was useful for this fairly interesting application.
Best regards,
