[Gdal-dev] OGRGeometry::Contains speed issue
Sean Gillies
sgillies at frii.com
Wed Feb 8 16:21:55 EST 2006
On Feb 8, 2006, at 1:44 PM, Rob McCulley wrote:
> Hi all,
> I've got a python script that runs through a bunch of shapefiles,
> performs an OGRGeometry::Transform on them, adds a couple of
> attributes, and merges them all into one final shapefile. All told
> it opens 76 shapefiles containing a total of ~18,000 polygons. It
> performs this in about 10 minutes.
> My area of interest is an irregular area which contains ~16,000 of
> the polygons. I added in a couple of lines to the script to check
> if the polygon was in the aoi, and set an attribute accordingly:
> point = newGeom.Centroid()
> aoiTest = aoiGeom.Contains(point)
> if aoiTest == 1:
> aoiVal = 1
> else:
> aoiVal = 0
> There shouldn't ever be a situation where a polygon will cross the
> aoi boundary, but I use a centroid for the Contains, just in case
> it isn't perfect.
> The problem I'm having is this makes things a lot slower. The
> first run through after adding those lines of code was ~17 hours
> (At the end the script outputs the run time in seconds). For my
> purposes, 17 hours is too long. I know that the aoi polygon is
> quite complex (~4000 vertices), and that probably slows things down
> a bit, but that much? Am I missing something, or is there a better
> way of doing this?
> Thanks
> Rob McCulley
> GIS Coordinator
> County of Vermilion River No. 24
> (780) 846-2244
> www.vermilion-river.ab.ca
Rob,
Try a two step approach:
1) if bounding boxes of the aoi and new geom intersect (fast):
2) make more rigorous evaluation of the intersection
aoiGeom.Intersects(newGeom) may be faster than computing the centroid
and containment.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
