[Gdal-dev] Building with Visual C++ 2005 Express
skotea at gmail.com
skotea at gmail.com
Thu Feb 9 08:59:16 EST 2006
Hi people !
Thanks for everything Simon it works (or in my case I hope it will) !
Everything seems good as I get that :
C:\warmerda
C:\warmerda\bld (only one subdir)
C:\warmerda\bld\bin
C:\warmerda\bld\data
C:\warmerda\bld\html
C:\warmerda\bld\include
But when I try to launch an exe from C:\warmerda\bld\bin I get this error
message (tranlsated from french) :
"This application cannot start because MSVCR80.dll is missing. Reinstalling
this application may solve the problem."
What did I miss ?
Thanks in advance people.
newbie scott (still trying a gdal compilation since december 05)
2005/12/31, Simon Perkins <sy at perkins.net>:
> For the benefit of other Visual C++ 2005 Express people, here's a summary
> of what I needed to do:
> 1) Download and install VC++ 2005 Express.
> 2) Download the Platform SDK, as described at:
> http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/
> 3) Set up paths in the IDE as described there. But also add the following
> two include paths:
> C:\Program Files\Microsoft Platform SDK\Include\atl
> C:\Program Files\Microsoft Platform SDK\Include\mfc
> 4) Since we build GDAL from the command line using nmake, I found I had to
> independently set up my LIB, INCLUDE and PATH environment variables to
> include the Visual C++ library, include and executable paths. The command
> shell that comes with VC++ does not unfortunately set these from the IDE
> options, so doesn't include the extra paths you add in the IDE... But that
> shell provides a good start - open it up and then copy the relevant bits of
> the above three variables to your system environment variables. Then add on
> the Platform SDK paths as above.
> 5) Modify the platform SDK atlbase.h file as described at:
> http://groups.yahoo.com/group/wtl/message/12850
> You don't actually need to install WTL for GDAL.
> 6) Everything should now compile using "nmake /f makefile.vc". If you do a
> nmake install or devinstall, then make sure the manifest files get copied
> along with the DLLs and EXEs. This should happen automatically with the
> latest CVS code.
> Next task, to check out those C# bindings so I never have to program in
> C++ again... :)
> Cheers,
> Sy
> Simon Perkins wrote:
> OK, got it all to work...
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060209/3dc9051f/attachment.html
