[Gdal-dev] GDALCreateReprojectionTransformer()
Sean Forde
sforde at lizardtech.com
Fri Feb 10 17:43:05 EST 2006
I have run in to some run time issues that can be tracked back to a failure in GDALCreateReprojectionTransformer(). The code snippet as it stands is...
<snip>
poForwardTransform = OGRCreateCoordinateTransformation(&oSrcSRS,&oDstSRS);
if( poForwardTransform == NULL )
// OGRCreateCoordinateTransformation() will report errors on its own.
return NULL;
/* Create a structure to hold the transform info, and also */
/* build reverse transform. We assume that if the forward */
/* transform can be created, then so can the reverse one. */
GDALReprojectionTransformInfo *psInfo;
psInfo = (GDALReprojectionTransformInfo *)
CPLCalloc(sizeof(GDALReprojectionTransformInfo),1);
psInfo->poForwardTransform = poForwardTransform;
psInfo->poReverseTransform =
OGRCreateCoordinateTransformation(&oDstSRS,&oSrcSRS);
</snip>
The problem is that psInfo->poReverseTransform is never checked. If OGRCreateCoordinateTransformation
failed and psInfo->poReverseTransform is NULL, then you will get a segfault later when you actually apply the reprojection. That is, it is assumed that psInfo->poReverseTransform is non-NULL.
To address this I would add the following lines:
<change>
if ( psInfo->poReverseTransform == NULL )
delete psInfo->poForwardTransform;
CPLFree(psInfo);
return NULL;
</change>
Doing so is consistent with the error handling for poForwardTransform a few lines previous.
I am not sure of the process for submitting patches, so apologies in advance if I am using the wrong venue.
-Sean
Sean Forde
Geospatial Engineering Manager
LizardTech, a Celartem Company
http://www.lizardtech.com
206-902-2874
