[Gdal-dev] Can't open a sid image under Russian locale
Sean Forde
sforde at lizardtech.com
Fri Feb 10 19:13:13 EST 2006
Peng,
I am not sure what the convention for the encoding of GDALOpenInfo->pszFileName. The mrsid driver expects poOpenInfo->pszFilename to be in OS-native encoding. If you are passing in UTF8, then it will be garbled.
I am not sure if this is a bug in the driver (i.e. should we be expecting poOpenInfo->pszFilename to be UTF8). If any one has clues as to the conventions/requirments of poOpenInfo->pszFilename, that would be helpful.
-Sean
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org]On Behalf Of Peng Gao
Sent: Thursday, February 09, 2006 3:25 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Can't open a sid image under Russian locale
GDAL can’t open a sid with a Russian path name. The problem seems to be the name conversion in
LTFileSpec. The following is the name before and after.
I am using DSDK 5.0.6
/* Create a corresponding GDALDataset. */
MrSIDDataset *poDS;
const LTFileSpec oFileSpec( poOpenInfo->pszFilename );
Before poOpenInfo->pszFilename:
“\\collingwood\checklist_data\Raster\I18N\Russian\фывdvim3_2.sid”
After oFileSpec.path8:
"\\collingwood\checklist_data\Raster\I18N\Russian\Р‡в€љС‚dvim3_2.sid"
