[Gdal-dev] Re: RasterIO tile size issue
Thu Feb 16 17:35:20 EST 2006
Sheykhet, Rostic wrote:
> Hi Frank, All:
> 	I have found an issue with GDALRasterIO() when dealing with very
> big(long) images and/or very small tile cache.  The problem seems to
> occur when RasterIO() attempts to write an area of a certain width (say
> AW) to an image with a smaller tile width (say BW), and the tile cache
> is not large enough to keep ceil(AW/BW) blocks cached.
> 	Assuming that the tile cache is completely turned off, here is
> the scenario that I am observing.  Passed-in buffer size = 128x128,
> image tile size=64x64.  RasterIO() starts writing the first line of the
> passed in buffer, acquires the first 64x64 block B[0,0] of the image and
> writes the first 64 samples to it.  Then it needs to continue writing
> the left-over 64 bytes of same line and therefore acquires the next
> block B[1,0] (to the right) and flushes B[0,0] block to disk.  After
> writing the last 64 samples of this scanline, it moves on to writing the
> second scan line, at which point the block B[0,0] is required again.  At
> this point, the code at line 286 of rasterio.cpp is executed:
>                 int bJustInitialize =
>                     eRWFlag == GF_Write
>                     && nYOff <= nLBlockY * nBlockYSize
>                     && nYOff + nYSize >= (nLBlockY+1) * nBlockYSize
>                     && nXOff <= nLBlockX * nBlockXSize
>                     && nXOff + nXSize >= (nLBlockX+1) * nBlockXSize;
> This code checks whether or not the block is completely contained within
> the area covered by the passed in buffer.  If so, the code simply
> allocates
> a new tile without reading the data that has already been written to
> disk.
> I think that a check should be put in for figuring out whether this
> RasterIO call has already written to this block, and the block should be
> read from disk, if that's the case.
Rostic,
I see your point.
However, even with the fix you suggest performance will still be just terrible
as blocks are swapped in and out for each scanline processed.  Instead, I
think I will try and come up with an approach where I hold all the blocks
"locked" till all the scanlines being written to them are complete.  This will
resolve a pathological performance case and resolve this bug all at once.
Does that seem reasonable to you?
Best regards,
