[Gdal-dev] problem building gdal in linux fedora core 1
Ari Jolma ari.jolma at tkk.fi
Mon Jan 2 06:49:28 EST 2006
Fernando González Cortés wrote:
> Hi Ari:
> 	As you guessed, the geos library I have built is installed into
> /usr/local/lib. I haven't that dir in /etc/ld.so.conf. But, ldconfig -v
> reports a geos library. I Installed long ago postgresql-postgis-7.4.1
> which needs geos-1.0. That version of geos is installed in /usr/lib and
> this one is the one the ldconfig command reports.
> 	I think it has to do with the problem, hasn't it? How can I tell the
> compiler to access the geos I've just installed instead of the old one?
for example
http://www.tldp.org/HOWTO/Program-Library-HOWTO/shared-libraries.html
gives some advice on how to do that, I don't have much experience with this
Ari
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
