[Gdal-dev] Continuing problems installing gdal-grass
Tue Jan 10 14:49:50 EST 2006
On 1/10/06, William Hudspeth <bhudspeth at edac.unm.edu> wrote:
> Thanks for responding Dan,
> I have followed your suggestions - it seems to have configured just
> fine. When I try to make, however, I get the following output:
> g++ -Wall -fPIC  -DUSE_CPL -DGRASS_GISBASE=\"/usr/local/grass-6.0.1\" -
> I/usr/local/gdal/include -I/usr/local/grass-6.0.1/include   -c -o
> grass57dataset.o grass57dataset.cpp
> In file included from grass57dataset.cpp:63:
> /usr/local/grass-6.0.1/include/gprojects.h:20:22: proj_api.h: No such file or directory
> /usr/local/grass-6.0.1/include/gprojects.h:31: syntax error before `*' token
> make: *** [grass57dataset.o] Error 1
William,
I think you will need to hand edit your Makefile and
add "-I/usr/local/include" or whatever is appropriate to
refer to the PROJ.4 include files.
Best regards,
