[Gdal-dev] hi, does GDAL supports shapefile?
Aaron Racicot
aaronr at z-pulley.com
Sun Jan 15 21:54:17 EST 2006
GDAL is for Rasters...
Check out OGR::
http://www.gdal.org/ogr/
It supports Shapefiles and much more.
Aaron
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Jason
Sent: Sunday, January 15, 2006 6:38 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] hi, does GDAL supports shapefile?
Hi, I am a fresh man in using GDAL. I read the document of GDAL, found
that shapefile (.shp) seems doesn't supported by GDAL. And I also try
used GDALOpen () to open a shapefile file, but got errors. Does GDAL
(gdal v1.22 )supports read/write of shapefile?
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
