Hi, I am a fresh man in using GDAL. I read the document of GDAL, found that shapefile (.shp) seems doesn't supported by GDAL. And I also try used GDALOpen () to open a shapefile file, but got errors. Does GDAL (gdal v1.22 )supports read/write of shapefile?
