[Gdal-dev] seg fault with ogr2ogr
palmerj at xtra.co.nz
Sun Jan 15 17:36:01 EST 2006
Hi Frank,
FYI: I wondering if the handling of the postgis 1.0 geometry type in the custom sql statements is not handled correctly. I tried modifying the previous statement to return WKB format and the queries now work correctly i.e.
ogr2ogr -f "Mapinfo File" testgis PG:dbname=testgis -sql \
"SELECT id,
AsBinary(transform(translate(shape,160,0,0),27200), 'NDR') AS wkb_geometry
FROM crs_parcel
WHERE status = 'CURR'
AND toc_code ='PRIM'
AND parcel_intent <> 'ROAD'
AND parcel_intent <> 'HYDR'" \
-nln parcel \
-a_srs EPSG:27200
Cheers
Jeremy
