[Gdal-dev] ogr2ogr with PostgreSQL 8.1
Bart van den Eijnden (OSGIS)
bartvde at xs4all.nl
Mon Jan 16 10:29:44 EST 2006
Hi list,
shouldn't the tables created by ogr2ogr explicitly specify WITH OIDS?
AFAIK all the Mapserver SQL assumes there is an OID column. I am using
the latest FWTools.
CREATE TABLE percelen_region
ogc_fid int4 NOT NULL DEFAULT
nextval('percelen_region_ogc_fid_seq'::regclass),
wkb_geometry geometry,
aanduid char(12),
gemcod char(5),
sectie char(2),
nummer char(5),
secnum char(7),
hoek numeric(8,3),
CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
CONSTRAINT enforce_geotype_wkb_geometry CHECK
(geometrytype(wkb_geometry) = 'MULTIPOLYGON'::text OR wkb_geometry IS NULL),
CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
WITHOUT OIDS;
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
