[Gdal-dev] ogr2ogr with PostgreSQL 8.1
Bart van den Eijnden (OSGIS)
bartvde at xs4all.nl
Mon Jan 16 10:55:53 EST 2006
Sorry, there seems no apparent need since in the MAP file the unique
column is overrideable, this is my use case which works fine:
CONNECTIONTYPE POSTGIS
CONNECTION "user=postgres dbname=gisarts host=127.0.0.1 port=5432
password=*****"
DATA "wkb_geometry from percelen_region USING UNIQUE ogc_fid"
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> shouldn't the tables created by ogr2ogr explicitly specify WITH OIDS?
> AFAIK all the Mapserver SQL assumes there is an OID column. I am using
> the latest FWTools.
> CREATE TABLE percelen_region
> ogc_fid int4 NOT NULL DEFAULT
> nextval('percelen_region_ogc_fid_seq'::regclass),
> wkb_geometry geometry,
> aanduid char(12),
> gemcod char(5),
> sectie char(2),
> nummer char(5),
> secnum char(7),
> hoek numeric(8,3),
> CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
> CONSTRAINT enforce_geotype_wkb_geometry CHECK
> (geometrytype(wkb_geometry) = 'MULTIPOLYGON'::text OR wkb_geometry IS
> NULL),
> CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
> WITHOUT OIDS;
> Best regards,
> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
