[Gdal-dev] gdal13.dll fails to load if called from different
directory (WinXP) - GIF format only
Sergey Malgin
smalgin at esri.com
Mon Jan 23 17:29:12 EST 2006
Ok, it sounds a bit confusing. Let me explain:
1. I have FOO_PLUGIN DLL that uses GDAL to read images
2. FOO_DLL is located under PLUGINS/FOO and loaded on-the-fly by the
process
3. GDAL13.DLL sits in DGAL_DIR. PATH variable has GDAL_DIR listed.
It all works OK for ECW, TIFF and MrSID. However, when I try to load GIFs,
LoadLibrary(FOO_PLUGIN.DLL) fails with Win32 code 126 (library couldn't be
found) and pop-up appears - 'GDAL13.DLL was not found'.
When I copy GDAL13.DLL into my process' working dir, it starts to complain
about HD420M.DLL etc etc.
All these DLLs are in GDAL_DIR together and yes, GDAL_DIR is listed in PATH.
Again, this only happens when I try to read GIFs. ECW, TIFF and MrSID
formats work OK.
I suppose I somehow should tell GDAL where GDAL13.DLL is located. But how? I
couldn't find anything in documentation.
This is my GDAL initialization code from FOO_PLUGIN.DLL:
GDALAllRegister();
CPLSetConfigOption("GDAL_PAM_ENABLED", "YES");
CPLSetConfigOption("USE_RRD", "YES");
CPLSetConfigOption("HFA_USE_RRD", "YES");
Any help would be greatly appreciated.
Sergey Malgin
ESRI, Inc
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060123/e5b0ac86/attachment.html
