[Gdal-dev] gdal13.dll fails to load if called from different
directory (WinXP) - GIF format only
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 23 19:51:33 EST 2006
On 1/23/06, Sergey Malgin <smalgin at esri.com> wrote:
> Ok, it sounds a bit confusing. Let me explain:
> It all works OK for ECW, TIFF and MrSID. However, when I try to load GIFs,
> LoadLibrary(FOO_PLUGIN.DLL) fails with Win32 code 126 (library couldn't be
> found) and pop-up appears – 'GDAL13.DLL was not found'.
Sergey,
I have no idea why this doesn't work for GIF, but does work for the
other file types. I *suspect* there is something different in how the
FOO_PLUGIN.DLL is built, but that is in your domain so I can't check.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
