[Gdal-dev] Cookie cutting shapefiles in OGR
Chapman, Martin MChapman at sanz.com
Tue Jul 4 16:13:54 EDT 2006
Matt,
I see your point.  Couldn't it be handled the same way other third party
drivers are handled?  Like ArcSDE or MrSID.  Or is that different?
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matthew Perry
Sent: Tuesday, July 04, 2006 12:46 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Cookie cutting shapefiles in OGR
On 7/4/06, Chapman, Martin <MChapman at sanz.com> wrote:
> 2.  If you actually want to clip intersecting geometries and reshape
> them to your cookie cutter geometry then you need to use a library
like
> GPC (http://www.cs.man.ac.uk/~toby/alan/software/ ). ......  If
> Frank W. is reading this posting I would urge him to consider
including
> GPC as part of OGR since it's small, fast, powerful, and easy to use.
The GPC licensing might make that tricky:
 "You may not use this software, in whole or in part, in support of
any commercial product without the express consent of the author."
This would conflict with GDAL/OGR's license quite a bit.
Matt Perry
perrygeo at gmail.com
http://www.perrygeo.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
