[Gdal-dev] ArcView binary raster support
Tue Jul 4 22:35:06 EDT 2006
Matt Wilkie wrote:
> Hi Vincent and interested coders,
>> Would it be possible to add support to gdal for native ArcView raster
>>  files, including other datatypes than simple ints, and (basic)
>> projection support?
>> BTW I send this message to the list rather than directly to Frank
>> because maybe others are interested too and willing to share the cost
> I think the ESRI format most likely to be recognised and utilised across
> the widest range of versions of ArcView & ArcGIS is ArcInfo GRID (the
> 'aig' driver to gdal).
> I'm not in a position to offer sharing of costs but I can certainly
> provide GRID rasters across the range of int types and projections for
> anyone who is interested in developing an AIG write driver for gdal and
> needs sample data.
Vincent / Matt,
I imagine Arc/Info Binary Grids are the most natural way to provide
raster support for ArcView.  Unfortunately, a fairly valiant effort on
my part to implement write support for this format a few years ago failed.
The format is undocumented, and while I was able to deduce enough information
about it to read it effectively, I was never able to write valid files.  I
am not terribly inclined to revisit this issue, though someone keen could
start from the existing file format definition (and perhaps I have some code)
and try to implement it.
Another format that is fairly well supported by ArcView is the .HDR labelled
BIL.  I have done some improvements in recent months to this driver and
you may find it suitable for some purposes.  However, it does not seem
to be a very expressive way of describing the data type (float vs. integer
for instance) which can be a problem.
I am open to other advice on good ways of exporting raster data in a form
that is useful in ArcView.
As Vincent mentioned, things should be better with ArcGIS (and hopefully
getting better with each new version of ArcGIS).
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
