[Gdal-dev] gdalwarp and gdal_translate question
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 7 21:57:08 EDT 2006
chantain greer wrote:
> Hi,
> I wanted to ask is there a techniqal difference between the way gdalwarp
> and gdal_translate scales the resolution of a file in pixels.
> gdalwarp uses the -ts option to set output file size in pixels and lines
> but gdal_translate uses -outsize to set the size of the output file.
> I wanted to find out if the output file would be the same if you used
> either technique.
Chantain,
In theory gdalwarp with the nearest neighbour resampling (the default)
should give similar results to gdal_translate when doing downsampling.
In practice there might be an "off by one" issue that would result in
picking different pixels for the downsampling. Basically gdalwarp
tries to be very precise about all the sampling while gdal_translate
tries to be fast and a bit careless of the details when changing
resolution.
Note that only gdalwarp includes other resampling kernels like
bilinear and bicubic.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
