[Gdal-dev] Problem with HDF4 samples
Daniele Romagnoli dany.geotools at gmail.com
Thu Jul 13 06:50:24 EDT 2006
> Daniele,
> Run gdalinfo –formats to see if you have the driver installed, you are
> using the gdal you build with c++ on windows recently I guess?
> The driver info is here
> http://www.remotesensing.org/gdal/gdal_building.html#gdal_building_libraries
> Norman
Hi Norman,
13 minutes after my first email, I have written a second one (^_^) :
Ok...
Stupid question :)
Now I'm downloading the HDF4 library.
I'm sorry...
Thank you.
Best Regards,
Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060713/4ab645a7/attachment.html
