[Gdal-dev] Python API
Shoaib Burq
hydromap at gmail.com
Fri Jul 21 11:15:05 EDT 2006
Maik
have a look at gdalautotest. There are plenty of examples under ogr dir
http://www.gdal.org/dl/gdalautotest-1.3.2.tar.gz
also there's some stuff here http://gdal.maptools.org/ogr/
generally speaking you can all the c++ api applies to python as well.
The convention in Python is that function names start with uppercase.
HTH
shoaib
On 7/18/06, Maik Trömel <maik.troemel at weather-consult.com> wrote:
> Hello list,
> i'm searching for a documentation how to work with GDAL/OGR with python.
> Probably somebody nows a link.
> Thanks for help.
> Greetings Maik
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
