[Gdal-dev] Python API
Sean Gillies
sgillies at frii.com
Fri Jul 21 12:24:20 EDT 2006
There's also good stuff at
http://hobu.biz/software/OSGIS_Hacks/index_html
On Jul 21, 2006, at 9:15 AM, Shoaib Burq wrote:
> Maik
> have a look at gdalautotest. There are plenty of examples under ogr
> dir
> http://www.gdal.org/dl/gdalautotest-1.3.2.tar.gz
> also there's some stuff here http://gdal.maptools.org/ogr/
> generally speaking you can all the c++ api applies to python as well.
> The convention in Python is that function names start with uppercase.
No, the Python convention is that function names start with
lowercase. Uppercase function names is a GDAL convention.
cheers,
Sean
> HTH
> shoaib
> On 7/18/06, Maik Trömel <maik.troemel at weather-consult.com> wrote:
>> Hello list,
>> i'm searching for a documentation how to work with GDAL/OGR with
>> python.
>> Probably somebody nows a link.
>> Thanks for help.
>> Greetings Maik
Sean Gillies
http://zcologia.com
