[Gdal-dev] which opendap library?
James Gallagher jhrg at mac.com
Thu Jun 8 12:45:39 EDT 2006
On Jun 7, 2006, at 6:46 PM, Christopher Condit wrote:
> Is the following library to be used to build opendap support on linux?
> http://www.opendap.org/download/libdap++.html#3.6.2
> I built this, but then when I add the –with-dods-root, it puts
> incorrect flags into the GDALmake.opt file…
> It appends /include to my path and /include/
> Seems like it should be just my include path and /GNU
You may need to check the version of libdap that gdal requires. I
have been making a fair number of changes to libdap and clients
generally need to be updated to use the newer versions. I think gdal/
ogr works with the 3.5 versions of the library, but to be honest, I'm
not sure.
James
> Thanks,
> Chris
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
James Gallagher                jgallagher at opendap.org
OPeNDAP, Inc                   406.723.8663
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060608/0016962a/attachment.html
