[Gdal-dev] RPF A.TOC Files
Chapman, Martin MChapman at sanz.com
Fri Jun 9 17:46:45 EDT 2006
Dave,
OSSIM can do it, and it can use GDAL as a plug-in data source as well.
http://www.ossim.org <http://www.ossim.org/>
Martin
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Murphy, David
Sent: Friday, June 09, 2006 2:04 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] RPF A.TOC Files
Hello-
Is there any way to read info from an RPF A.TOC file via OGDI (gltp)?  I
need to programmatically determine the number of frame (tile) files in
an RPF dataset.  Also, is there any documentation on the layout of an
RPF A.TOC file?
Thanks,
Dave Murphy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060609/fd4ce18b/attachment.html
