[Gdal-dev] ogr2ogr issues for vmap0 on Ubuntu Breezy
Putler, Dan
Dan.Putler at sauder.ubc.ca
Sun Jun 11 16:44:04 EDT 2006
Hi All,
I'm trying to convert some vmap0 files to shapefile format (the
political boundary polygons to be exact) using ogr2ogr on an Ubuntu
"Breezy" system. I first used the FWTools 1.0.0b2 build of ogr2ogr to
do this. When doing the conversion, ogr2ogr doesn't complain, but
only writes out the field names and formats in the dbf along with the
prj file. The shp and shx file are created, but the don't appear to
have any actual information in them. Following this, I rebuilt the
gdal 1.3.1 library with ogdi support, and tried again, with the same
outcome (on all four vmap0 databases, so I don't think it is a
corruption issue). My guess is that I'm running into an Ubuntu
specific issue, but I'm not sure. Any ideas?
On a related note, if someone has copies of the shapefile versions of
the political boundaries, allowing me to obtain them from you would
be greatly appreciated (yes, it is giving a man a fish, not teaching
him to fish, but it solves my short term problem).
Dan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060611/a604d649/attachment.html
