[Gdal-dev] gdaltindex on numerous files
Mateusz Loskot mateusz at loskot.net
Wed Jun 14 10:34:27 EDT 2006
Kralidis,Tom [Burlington] wrote:
> Hi,
> I'm trying to create a MapServer tileindex via gdaltindex, where I
> would like to store the absolute paths to each raster image in the
> output tileindex.
> Trying this gives me the following error:
> $ gdaltindex srtm-index2 $PWD/*.tif
> -bash: /usr/local/bin/gdaltindex:
> Argument list too long
Hmm, I'd suppose the problem is with your shell environment.
I use GNU Bash 3.1.17 and your command works well:
mloskot:~/data/samples$ gdaltindex ind $PWD/workshop/*.tif
mloskot:~/data/samples$ dbfdump -h ind
Field 0: Type=String, Title=`location', Width=255, Decimals=0
location
/home/mloskot/data/samples/workshop/drgncimq1926.tif
/home/mloskot/data/samples/workshop/drgncimq1942.tif
but if I run without $PWD:
mloskot:~/data/samples$ gdaltindex ind workshop/*.tif
gdaltindex produces relative paths:
location
and that's normal behaviour.
gdaltindex takes paths as it gets. If you call with
$PWD/workshop/*.tif
the path is constructed as follows:
/home/mloskot/workshop/ + <filename>.tif
> Does gdaltindex take a filelist as an argument?
No, it does not.
MapServer's tile4ms takes metafile with input files list.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
