[Gdal-dev] Compile GDAL with VS2005 (BuildKit Source Code)
Didrik Pinte dpinte at itae.be
Thu Jun 15 03:04:34 EDT 2006
Le mercredi 14 juin 2006 à 22:36 +0200, Zhonghai Wang a écrit :
> Hi Howard,
> thanks you so much for the important HINTS.
> so you mean that I must compile all the needed libraries in the
> BuildKit package myself with VS2005? Is this compilation guide still
> valid for the whole compilation?
> http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024>http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024.
> so the steps may be:
> 1. compile the required libraries for GDAL (according to the component
> that I need)
> 2. compile GDAL
> 3. compile the required libraries for MapServer
> 4. compile MapServer
> and here is the last question^_^:
> what does the command "nmake /f makefile.vc install" mean? for this
> command which parameters in the nmake.opt file should be set
> correctly?
> I really appreciate your help.
> best regards
> zhonghai
Another solution can be the use of the MSVC Toolkit, freely available on
the MS website. With this toolkit you have everything needed for
MSVC2003 compliant compilation. I've build geos, gdal, proj from scratch
using it. I can provide more details if needed.
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060615/fd041b8c/attachment.bin
