[Gdal-dev] Compile GDAL with VS2005 (BuildKit Source Code)
Zhonghai Wang
zhonghaiw at gmail.com
Thu Jun 15 03:36:19 EDT 2006
Hi Dirik,
you mean that I do not need to compile all the needed libraries from the
very begining?
the problem is now I want to compile GDAL and MapServer with VS2005, but the
needed Libraries by GDAL and MapServer were pre-compiled with VS2003, as
Howard said.
I'd like more details about the compilation.
thank you very much.
zhonghai
On 6/15/06, Didrik Pinte <dpinte at itae.be> wrote:
> Le mercredi 14 juin 2006 à 22:36 +0200, Zhonghai Wang a écrit :
> > Hi Howard,
> > thanks you so much for the important HINTS.
> > so you mean that I must compile all the needed libraries in the
> > BuildKit package myself with VS2005? Is this compilation guide still
> > valid for the whole compilation?
> http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024
> > so the steps may be:
> > 1. compile the required libraries for GDAL (according to the component
> > that I need)
> > 2. compile GDAL
> > 3. compile the required libraries for MapServer
> > 4. compile MapServer
> > and here is the last question^_^:
> > what does the command "nmake /f makefile.vc install" mean? for this
> > command which parameters in the nmake.opt file should be set
> > correctly?
> > I really appreciate your help.
> > best regards
> > zhonghai
> Another solution can be the use of the MSVC Toolkit, freely available on
> the MS website. With this toolkit you have everything needed for
> MSVC2003 compliant compilation. I've build geos, gdal, proj from scratch
> using it. I can provide more details if needed.
> Didrik
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (GNU/Linux)
> iD8DBQBEkQaC9Rlh4Zs4yBMRApdjAJ9FP6bDbHIFsrgsvaVz6TzfLtyxiQCfXNMf
> NVgWUPh+1wBuJ1byrcVzSxM=
> =thGh
> -----END PGP SIGNATURE-----
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060615/23018803/attachment.html
