[Gdal-dev] DBF-Column type boolen and date?
Frank Warmerdam
warmerdam at pobox.com
Mon Jun 19 08:50:11 EDT 2006
Markus Neteler wrote:
> Frank,
> I was thinking moreover about the DATE support in the
> GRASS DBF driver:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/db/drivers/dbf/globals.h?rev=HEAD&content-type=text/vnd.viewcvs-markup
> Currently only FTString, FTInteger, FTDouble are used and
> date is mapped to char since FTDate isn't there (but was proposed
> by strk). That's why I brought up the issue here.
> I am not sure how to change the GRASS DBF driver to better implement
> date support (mayeb there is nothing to change?). See line 313 in
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/db/drivers/dbf/dbfexe.c?annotate=1.36
Markus,
Some roughly comparable code is in ogrshapelayer.cpp. As you can
see OFTDate is transferred using DBFAddNativeFieldType() instead of
the DBFAddField() so the specialized date type can be created.
/* CreateField() */
OGRErr OGRShapeLayer::CreateField( OGRFieldDefn *poField, int bApproxOK )
int iNewField;
if( GetFeatureCount(TRUE) != 0 )
CPLError( CE_Failure, CPLE_NotSupported,
"Can't create fields on a Shapefile layer with features.\n");
return OGRERR_FAILURE;
if( !bUpdateAccess )
"Can't create fields on a read-only shapefile layer.\n");
if( poField->GetType() == OFTInteger )
if( poField->GetWidth() == 0 )
iNewField =
DBFAddField( hDBF, poField->GetNameRef(), FTInteger, 11, 0 );
else
iNewField = DBFAddField( hDBF, poField->GetNameRef(), FTInteger,
poField->GetWidth(), 0 );
if( iNewField != -1 )
poFeatureDefn->AddFieldDefn( poField );
else if( poField->GetType() == OFTReal )
iNewField =
DBFAddField( hDBF, poField->GetNameRef(), FTDouble, 24, 15 );
else
iNewField =
poField->GetWidth(), poField->GetPrecision() );
else if( poField->GetType() == OFTString )
if( poField->GetWidth() < 1 )
iNewField =
DBFAddField( hDBF, poField->GetNameRef(), FTString, 80, 0 );
else
iNewField = DBFAddField( hDBF, poField->GetNameRef(), FTString,
else if( poField->GetType() == OFTDate )
iNewField =
DBFAddNativeFieldType( hDBF, poField->GetNameRef(), 'D', 8, 0 );
else if( poField->GetType() == OFTDateTime )
CPLError( CE_Warning, CPLE_NotSupported,
"Field %s create as date field, though DateTime requested.\n",
poField->GetNameRef() );
iNewField =
else
"Can't create fields of type %s on shapefile layers.\n",
OGRFieldDefn::GetFieldTypeName(poField->GetType()) );
return OGRERR_NONE;
else
CPLError( CE_Failure, CPLE_AppDefined,
"Can't create field %s in Shape DBF file, reason unknown.\n",
and watch the world go round - Rush | President OSGF, http://osgeo.org
